This is the error I am recieveing
An exception occurred when instantiating a Com object. The cause of this exception was that:
coldfusion.runtime.com.ComObjectInstantiationException: An
exception occurred when instantiating a Com object..
I have seen others having this same issue, but a solution
have never been supplied.
The com pool can be accessed with admin priveleges in:
Start Menu > Programs > Administrative Tools >
Component Services
drill down to COM+ Applications and checked the icon for your
COM is rotating...
If it's not - right-click and select Start
If it is - right click and select 'Shut Down', then
right-click and select 'Start'
I am getting the same error but for a Word application.
Please check if you have MSXML 4.0 installed. If not, then install
it 'coz I think thats needed for COM objects. But I got a little
different error after that. But definitely install MSXML 4.0.
Although folks have had some success with Office objects,
Microsoft does NOT recommend that you run them in a server
environment. They're designed only for desktop use; they don't exit
gracefully (check out the process list sometime); they're not
supported when used this way.
