Excel COM Object
Participant ,
May 08, 2006 May 08, 2006
This is the error I am recieveing
An exception occurred when instantiating a Com object.
The cause of this exception was that: coldfusion.runtime.com.ComObjectInstantiationException: An exception occurred when instantiating a Com object..
I have seen others having this same issue, but a solution have never been supplied.
Advanced techniques
579
Participant ,
is the com component rotating in the com pool?
jam
Participant ,
May 09, 2006 May 09, 2006
What do you mean by "rotating in the com pool"?
Participant ,
May 22, 2006 May 22, 2006
The com pool can be accessed with admin priveleges in:
Start Menu > Programs > Administrative Tools > Component Services
drill down to COM+ Applications and checked the icon for your COM is rotating...
If it's not - right-click and select Start
If it is - right click and select 'Shut Down', then right-click and select 'Start'
Guest
I am getting the same error but for a Word application. Please check if you have MSXML 4.0 installed. If not, then install it 'coz I think thats needed for COM objects. But I got a little different error after that. But definitely install MSXML 4.0.
Participant ,
I'm using a shared host who says they do have the MS components installed. They're installed on every account as standard practice.
Contributor ,
May 10, 2006 May 10, 2006
Although folks have had some success with Office objects, Microsoft does NOT recommend that you run them in a server environment. They're designed only for desktop use; they don't exit gracefully (check out the process list sometime); they're not supported when used this way.
Good luck.
Documentation
