hi
i have create a virtual keyboard for english and tamil with backend process.
i have created tat virtual keyboard using custom component.
i have used that customcomponent(vkey.mxml)in main.mxml file
i have build the ant build.xml file .
that time it build sucessfully.
if i change any alignment or any thing i have build one more time.
that time i have received on hs_err_pid5032.log containing
A fatal error has been detected by the Java Runtime Environment.
jav.lang.outofMemoryError:requested 32756 bytes for chunkpool:allocated. out of swap space?
this is the error
how i rectify this error.
if i have build one more time the flashbuilder 4 and plugin eclipse application terminated.
regards
athi
Oh okay ! It seems to be a fairly small project only.
Did the -Xmx work ? Is your issue solved ?
Balakrishnan V
From the looks of it, it seems to be an out of memory error with the JVM.
http://nlc.nlc.go.cn/resin-doc/performance/jvm-tuning.xtp - This can help you increase the max. heap size in your JVM.
You would have better luck posting the same query in the Flex forum - http://forums.adobe.com/community/flex/flex_general_discussion
Also, if you specify some details about your environment, your project file descriptions etc., I could be more helpful.
Hope this helps,
Balakrishnan V
hi
my environment
1..flashbuilder 4 plugin with eclipse helios
2.java
3.mysql
4.windows xp
i dont know where i increase the heap size .
pls
give me ideas
regards
athi
In the command line, java -Xmx<size>
If you type, java -X and press enter, it lists the options available.
Is you application huge ? How many mxml files / .as files are you having ?
Balakrishnan V
hi
thans a lot fr ur reply
i enter java -Xmx 512
then it returns invalid maximum heap size:-Xmx
could not create the hjava virtual machine
can i send my mxml file
regards
athi
No space between -Xmx and 512.
It is just java -Xmx512M.
And sorry, I forgot to mention. You have to give M(MB) or K(KB)
Sending your mxml file would be unnecessary. Is your project a large project ? (How many mxml/as files in all)
hi
i have two mxml files
one is custom component engkeyboard.mxml
and another one is main.mxml
custom component engkeyboard.mxml contains java backend process.
so
this project folder contains
virtualVo.as
virtualVo.java
virtualServiceDAO.java
and assets folder contains some fonts .ttf files
regards
athi
Balakrishnan V
hi
the -Xmx works well
but i got the error just "null "
regards
athi
Where did you get null ? Could you elaborate ?
hi
i have build the mxml files using build.xml
That time i got the error "null". and "build failed".
regards
viji
You would have better luck trying in the Flex Forum - http://forums.adobe.com/community/flex/flex_general_discussion
By the way, does it work fine when you dont specify the -Xmx.
If so, try increasing the -Xmx value and then build.
balakrishnan v
hi
thanks a lot
regards
athi
Just in case, try and see if this helps. (This is just an alternative way of setting the Xmx for JVM)
Go to the eclipse-dir/eclipse.ini config file and change the -Xmx value.
Hope this helps,
Balakrishnan V
