I'm recording a screen that has text moving across the top from right to left.
I record the screen, press F9 to start the FMR and then press F10 to end the FMR. Cp4 puts the video camera on the screen but the screen capture shrinks significantly in Edit mode. It's so small you cannot see it. However, when I view the screen in Preview:Project or Preview:In Web Browser it looks fine. This doesn't happen every time I use manual FMR, just sometimes.
Is there a setting or something I can change to enable the screen capture on the FMR slides to be regular size?
ps...I also noticed the animated arrows are behaving the same way. When I Insert:Animation and choose the SWF arrows, in Edit mode, the arrows are too small to see however they do appear properly in Preview: Project mode.
Thank you in advance for any advice.
Welcome to our community
Please take a moment and look over one of the links you were intended to discover as you landed in the Captivate forums. Specifically, the link below. The answer to your issue is indside it.
Click here to view the Frequently Encountered Issues thread.
Cheers... Rick
Helpful and Handy Links Begin learning Captivate 5 moments from now! $29.95 Captivate Wish Form/Bug Reporting Form |
Cheers... Rick
Hi Rick,
RJ just lanced this Tweet:
[News] Flash Player 10.1.82.76 Fixes Adobe Captivate 4: http://bit.ly/cQrlGw #AdobeCaptivate.
Lilybiri
PS: to be honest, did not try yet
Thank you. This appeared to have fixed the issue. I wasn't able to install Flash Player 10
.1.82.76 as I got that message right after I ran the fix you sent me. But, it's good to know. Thanks
again!
