I recently upgraded to Robohelp HTML 8.0.2.208 from RoboHelp HTML 7.x and I use the WebHelp output.
Without having to tell customers (this is a last resort) to enable the IE 8 setting "Display All Websites in Compatibility View," does anyone have any idea how to prevent the Related Topics' links from being underlined with inconsistent colors? Am I missing where the related topics' formats are underlined? Also, my drop-down text within topics is inconsistently underlined (some drop-down text links are underlined, which is my preference, and some are not).
Formerly, my Related Topics' hyperlinks looked like:
Now, the Related Topics design-time control in the Compiled WebHelp now looks like:
My RoboHelp 8 HTML code:
<!--Metadata type="DesignerControl" startspan
<object classid="clsid:FF80F713-5DC6-11d0-A7B4-00AADC53E937">
<param name="_Version" value="65536" />
<param name="_ExtentX" value="2032" />
<param name="_ExtentY" value="423" />
<param name="_StockProps" value="13" />
<param name="ForeColor" value="0" />
<param name="BackColor" value="14215660" />
<param name="UseButton" value="-1" />
<param name="UseText" value="0" />
<param name="ControlLabel" value="Related Topics" />
<param name="UseIcon" value="-1" />
<param name="Items" value="Document Access Report;Document_Access_Report.htm$$**$$PaperVision Enterprise Reports;Working_with_reports.htm$$**$$System Operations Report;System_Operations_Report.htm$$**$$Utilization Report;Utilization_reports.htm$$**$$Workflow History Report;Workflow_History_Report.htm$$**$$Workflow Status Report;Workflow_Status_Report.htm$$**$$"
<param name="Image" value="relatedtopicsGREEN.bmp" />
<param name="FontInfo" value="Microsoft Sans Serif,8,0,," />
<param name="_CURRENTFILEPATH" value="C:\RoboHelp Test\RoboHelp Working Files\Archived_Reports.htm"
<param name="_ID" value="" />
<param name="UseMenu" value="-1" />
<param name="Frame" value="" />
<param name="Window" value="" />
</object>--><object
classid="clsid:ADB880A6-D8FF-11CF-9377-00AA003B7A11"
type="application/x-oleobject" >
<param name="Command" value="Related Topics,MENU" />
<param name="Button" value="Bitmap:relatedtopicsGREEN.bmp" />
<param name="Font" value="Microsoft Sans Serif,8,0,," />
<param name="Item1" value="Document Access Report;Document_Access_Report.htm" />
<param name="Item2" value="PaperVision Enterprise Reports;Working_with_reports.htm" />
<param name="Item3" value="System Operations Report;System_Operations_Report.htm" />
<param name="Item4" value="Utilization Report;Utilization_reports.htm" />
<param name="Item5" value="Workflow History Report;Workflow_History_Report.htm" />
<param name="Item6" value="Workflow Status Report;Workflow_Status_Report.htm" />
</object>
<!--Metadata type="DesignerControl" endspan-->
Any suggestions are appreciated.
1972DanaT,
I had the opposite problem - inconsistent underlines in Firefox. I simply controled them in CSS:
/* Display "Related Topics" link in FF without the default underline */
a[title=" Related Topics"] {
text-decoration: none;
/* Display "Related Topics" popup without intermittent underline in FF */
div#PopupMenu a {
Patrick
Set up a simple test in a new project using the default CSS and see if things are consistent there.
If they are, then I suspect some inline styling is coming into play. Post back after you have checked that out.
Peter, I set up a simple WebHelp project and the same thing happened with inconsistent underline colors when viewing in IE8:
The HTML code for the Related Topics Design-Time Control:
<param name="_ExtentX" value="2138" />
<param name="_ExtentY" value="508" />
<param name="BackColor" value="15790320" />
<param name="UseButton" value="1" />
<param name="UseIcon" value="0" />
<param name="Items" value="Test1;Test1.htm$$**$$Test2;Test2.htm$$**$$Test3;Test3.htm$$**$$"
<param name="Image" value="" />
<param name="_CURRENTFILEPATH" value="C:\WebHelpTest\WebHelp_Test\Intro.htm"
<param name="UseMenu" value="1" />
</object>-->
<object
<param name="Button" value="Text:Related Topics" />
<param name="Item1" value="Test1;Test1.htm" />
<param name="Item2" value="Test2;Test2.htm" />
<param name="Item3" value="Test3;Test3.htm" />
</object>
1972DanaT,
div#PopupMenu a {
Patrick
Thanks, Patrick - that did the trick for intermittent colors/underlines in the popup within the Related Topics' design-time control. Next, I'll try to fix the inconsistency in the drop-down text:
--Dana
