1. Re: Transparent layer zoom - CS4 vs. CS5
John Joslin Aug 11, 2010 2:44 AM (in response to nina1234567)You can change it in Edit > Preferences > Transparency and Gamut > Grid Size
2. Re: Transparent layer zoom - CS4 vs. CS5
nina1234567 Aug 11, 2010 3:02 AM (in response to John Joslin)Hi Josh,
That doesn't fix it! This will only make the grid "in general" smaller or bigger, but as you can see in my screenshots:
Both screenshots are zoomed to the size of 3200%!!Greetz,
nina
3. Re: Transparent layer zoom - CS4 vs. CS5
John Joslin Aug 11, 2010 3:28 AM (in response to nina1234567)It changes the size of the checkerboard – there is even a preview.
If that doesn't help, I can't think of anything else.
I don't spend much time with empty layers zoomed to 3200% so it doesn't bother me.
4. Re: Transparent layer zoom - CS4 vs. CS5
nina1234567 Aug 11, 2010 3:48 AM (in response to John Joslin)Yes - that's what I meant with "grid": the checkerboard!
Well, and as you can see, the checkerboard in CS5 zooms too if you want to get closer, while the size of the checkerboard in CS4 remains!
And I of course checked the preferences before but I couldn't find any way to disable this "zooming with zoom".
5. Re: Transparent layer zoom - CS4 vs. CS5
Zeno Bokor Aug 11, 2010 5:32 AM (in response to nina1234567)It might be video card related, try disabling OpenGL Drawing from Edit->Preferences->Performance
6. Re: Transparent layer zoom - CS4 vs. CS5
nina1234567 Aug 11, 2010 5:47 AM (in response to Zeno Bokor)Hi Zeno,
I have to admit: it works! You are absolutely right: because although there is OpenGL already in my CS4, I never enabled it.
But now I would like to use the OpenGL: I cannot use any of the cool new CS5 stuff like "point-zooming" with the magnifier-icon, smooth panning, etc. if I disable the function.
So we now know that it is up to the OpenGL mode. Does anyone now know how I can have BOTH: OpenGL AND the checkboard "un-zoomed"?
nina
7. Re: Transparent layer zoom - CS4 vs. CS5
Zeno Bokor Aug 11, 2010 6:31 AM (in response to nina1234567)Updating your video card drivers usually fixes such problems so give it a try.
8. Re: Transparent layer zoom - CS4 vs. CS5
John Joslin Aug 11, 2010 6:58 AM (in response to Zeno Bokor)Zeno Bokor wrote:
But don't rely on Windows Device Manager – go to the manufacturer's web site and check. -
9. Re: Transparent layer zoom - CS4 vs. CS5
MTSTUNER Aug 11, 2010 9:09 PM (in response to nina1234567)In the cs5 Preferences>Performance>Open GL Drawing>Advanced settings,
try normal or advanced instead of basic.
MTSTUNER
10. Re: Transparent layer zoom - CS4 vs. CS5
nina1234567 Aug 11, 2010 11:41 PM (in response to MTSTUNER)YEAHH!!!!!! It works!!! MTSTUNER, great job! Now my problem is really solved!!!! So cool!
Thanks a lot!
Amazing! Amazing! Amazing!
Have a wonderful day!
Greetz,
nina
11. Re: Transparent layer zoom - CS4 vs. CS5
Noel Carboni Aug 12, 2010 11:02 AM (in response to nina1234567)function(){return A.apply(null,[this].concat($A(arguments)))}
It's an OpenGL programming issue, plain and simple. The scaling for the image texture is being applied to the checkerboard texture.Clearly they're taking a different approach with Normal mode than Basic.
I've just dealt with exactly the same issue in my own code recently.
-Noel
