1. Re: NetStream.Record.NoAccess
AbhishekSinha Aug 12, 2010 10:53 AM (in response to nurba)This status message generally indicates that you don't have write permissions to the stream. Check the permissions of your streams dir to see if it is read only.
If that is not the issue, check which application are you trying to publish to, does not SSAS that has code to deny write access to stream
Abhishek
2. Re: NetStream.Record.NoAccess
nurba Aug 12, 2010 11:12 AM (in response to AbhishekSinha)It is recording 10-20 minutes sometimes, sometimes 2 minutes only,
If that folder doesnt have write permission, it should not record video
my problem is recording stops after a few minutes later
3. Re: NetStream.Record.NoAccess
AbhishekSinha Aug 12, 2010 11:48 AM (in response to nurba)Oh Sorry,
I think I did not get your questions clearly the first time. What format are you publishing and recording in? Also have you checked FMS logs to see if there is something that indicates such action
Abhishek
4. Re: NetStream.Record.NoAccess
nurba Aug 12, 2010 8:23 PM (in response to AbhishekSinha)I tried publishing as h264 and sorenson codec, recording as f4v
live stream is working fine, I can watch the live stream,
but only recording stops after a few minutes later,
in the logs I am getting NetStream.Record.NoAccess error and says recording stopped
5. Re: NetStream.Record.NoAccess
zenmaier Sep 27, 2010 8:52 AM (in response to nurba)I have almost the same problem, unless I really can't record with FMIS or FMDS.
it says NetStream.Record.NoAccess instantly.
all permissions of my linux box are ok (nobody.nobody) no SSAS code that unauthorize write access.
but, on this subject, is there any example of SSAS code script on this matter ?
6. Re: NetStream.Record.NoAccess
juwang Sep 7, 2011 11:38 PM (in response to nurba)I have a almost problem.
fms version:fms3.5.3
fms is working on nobody.nobodyI check the record directory, is seem no problem.
fms src:
myStream.play("mp4:vc_live/upload/recorded/recordfile.mp4");fms.ini:
RECORDING.DIR = vc_live;/var/www/myprojectdirectory permission:
[nobody@fmsvm myproject]$ ll
drwxrwxrwx 6 webapp 4.0K Sep 5 16:04 upload/
[nobody@fmsvm upload]$ ll
drwxrwsrwx 3 webapp 12K Sep 8 13:27 recorded/file is exist but filesize always stoped on 21K.
[nobody@fmsvm recorded]$ ll fc148c16bf1232058e0bfdd3b7e806ac6deca4b8*
-rw-r--r-- 1 webapp 8 Sep 8 14:46 fc148c16bf1232058e0bfdd3b7e806ac6deca4b8.log
-rw-rw---- 1 nobody 21K Sep 8 14:46 fc148c16bf1232058e0bfdd3b7e806ac6deca4b8.mp4
[nobody@fmsvm recorded]$ ll 1df76f66e882ee5036ea4f5a734ce9c1cae50254*
-rw-r--r-- 1 webapp 8 Sep 8 15:23 1df76f66e882ee5036ea4f5a734ce9c1cae50254.log
-rw-rw---- 1 nobody 21K Sep 8 15:23 1df76f66e882ee5036ea4f5a734ce9c1cae50254.mp4
(webapp is web server user ,recordfile.log is chatlog) -
7. Re: NetStream.Record.NoAccess
calmchessplayer Sep 8, 2011 8:50 AM (in response to juwang)You know I had a person with not quite this problem but a very similar problem. I suggested he chmod -R 777 /whatever/dir but he didn't listen to me instead he reinstalled FMS on Linux as root or some other power user depends on your Linux distro but by not useing nobody.nobody he fixed the problem. Please forgive me if the syntax of chmod is incorrect or not secure enough for you I haven't used chmod in months but 777 will give you permissions that you need. I've used it before. out of curiosity what Linux Distro are you guys using? You might also be able to use chown and change the owner of the applications/app directory with success.
8. Re: NetStream.Record.NoAccess
Nikhil Pavan Kalyan Sep 17, 2011 7:19 PM (in response to calmchessplayer)Hi all,
Is this problem resolved or is it still hurting you guys ? Please let us know. Thank you
9. Re: NetStream.Record.NoAccess
juwang Sep 20, 2011 9:44 PM (in response to Nikhil Pavan Kalyan)thanks for your replay > calmchessplayer
I try to
1. change record directory to /tmp . problem is still..
2. upgrade fms version to fms3.5.5 . problem is still..
more information:
publish format:h264 mp3
linux version:Linux fmsvm.example.com 2.6.32-71.el6.x86_64 #1 SMP Fri May 20 03:51:51 BST 2011 x86_64 x86_64 x86_64 GNU/Linux
Please help me > Nikhil Pavan Kalyan
10. Re: NetStream.Record.NoAccess
Nikhil Pavan Kalyan Sep 20, 2011 10:00 PM (in response to juwang)hi,
You previously mentioned that you are seeing a 21kb file being created, is that still correct ?
If that's the case, the problem is with the wrong type of content going into the recording and hence the server is not copying the data into the file and just discarding it.
Your publish format h264 and mp3 are both supported, but what is the file format you mentioned for recording ? Is it FLV or F4V? You mentioned using mp4: in the ns.play command, but are you using the mp4: in the publish command as well?
Please also check your FMS log files to see if there are any errors in recording.
11. Re: NetStream.Record.NoAccess
juwang Sep 21, 2011 2:13 AM (in response to Nikhil Pavan Kalyan)thanks for your help
I check the FMS core.00.log and get the following message:
2011-09-21 11:27:59 726 (e)2611178 Error from libmp4.so: No Space left in the stsd box. - 2011-09-21 11:27:59 726 (e)2611423 Failed to record vc_live/upload/recorded/ab91a04be0d3669bdf80d645b6413362db69a09f.mp4 (Unknown Error). - and search the message 'libmp4.so: No Space left in the stsd box.' .
I find the url:http://forums.adobe.com/thread/451911 get some hint.
I use FMLE with Auto Adjust option on ,when the error came.
I try to turn off Auto Ajust option then error has disappeared.
Please excuse my poor English.
12. Re: NetStream.Record.NoAccess
Christofer L Aug 30, 2012 5:43 AM (in response to nurba)Hi,
I'm experiencing a similar problem, the recoring stops after different durations each time but the files are being written correctly to disk.
We are seeing the error messages "Error from libf4f.so: F4V error: 1280" and "NetStream.Record.NoAccess"
13. Re: NetStream.Record.NoAccess
G-Software Aug 30, 2012 5:48 AM (in response to Christofer L)Hi,
after some tests maybe it seems to be a too weak buffer problem. but no sure
14. Re: NetStream.Record.NoAccess
Christofer L Aug 30, 2012 6:28 AM (in response to G-Software)Which settings do you suggest we tweak to see if it makes a difference?
15. Re: NetStream.Record.NoAccess
G-Software Aug 30, 2012 7:07 AM (in response to Christofer L)buffer depends of the a/v quality you broadcast.
so for example 720p 30fps quality (if you use H.264) requires at least
14000Kb/s, so if you broadcas with a 1mb up bandwidth so it needs at least
14s of bffer...
16. Re: NetStream.Record.NoAccess
Christofer L Sep 5, 2012 6:58 AM (in response to G-Software)This seemed to help at first, I don't see the error messages anymore but the recording still stops after a few minutes.
The setup looks like this: we have our live application which re-streams to a recording application on the same FMS.
Now when the recording stops the recording application receives a NetStream.Play.UnpublishNotify event but there is no indication in the live application that the stream have been unpublished, the stream is still published just fine. During the last test it just stopped without even receiving the event, the only way to see this was the drop in bandwidth usage for the recording application in the FMS Administration Console.
17. Re: NetStream.Record.NoAccess
G-Software Sep 5, 2012 7:27 AM (in response to Christofer L)I solved my "noAccess" problem after a recording by simply a Stream.cleart() t prior to record
first as the live stream is readonly.
18. Re: NetStream.Record.NoAccess
Dmitry Nikolaev Jun 11, 2014 12:55 PM (in response to nurba)Problem is still exist. I can explain detailed with log file how that happens. Anyone can help us?
19. Re: NetStream.Record.NoAccess
vijay.das Jul 1, 2014 5:23 AM (in response to Dmitry Nikolaev)if you are seeing the error related to stsd entries, i posted a reply on this thread Stream records for sometime and then gives Stream.Record.NoAccess
20. Re: NetStream.Record.NoAccess
Nicolas Dion-Bouchard Jul 23, 2014 7:38 AM (in response to nurba)There clearly seems to be a problem with mp4/f4v recording using h264 codec. Can it be a week buffer problem as G-Software mentioned? We have the same problem, publishing live stream with h264 and sorenson and recording the stream on server-side. So the stream is published in "live" mode from the client then the server creates another Stream object and attaches the live stream to it in order to record the new one. We use this strategy because we are not always recording as the client can freely activate/deactivate the recording feature as the meeting goes on. Randomly, we get the same NoAccess message and the record stops. Any idea anyone? I think that's a bug, especially because we don't get any more specific error in the logs...
