1. Re: Placing grouped library element in anchor
dhishok Aug 12, 2010 10:06 PM (in response to Green4ever)Hi,
The library element should be a grouped object while placing it into inline text, otherwise your coding seems to be correct.
ashok
2. Re: Placing grouped library element in anchor
Green4ever Aug 13, 2010 10:05 AM (in response to dhishok)Hi
Have you got the result for my code, is it working? I too think that it was correct but its not working. Can u help on this regard...
Thanks...
3. Re: Placing grouped library element in anchor
dhishok Aug 13, 2010 11:18 PM (in response to Green4ever)Hi,
I have checked it too. First of all you need to check your library element, if it is a grouped object or set of loose frames?
Have you checked it?
Otherwise mention the exact script error or its screen shot.
ashok
4. Re: Placing grouped library element in anchor
Green4ever Aug 14, 2010 11:11 AM (in response to dhishok)Hi ashok...
It is working fine.. I think the problem is because of the two libraries are opened at the same time. First i checked in my machine it was not working and after that I tried in another machine and finally i got the result... Thanks for ur valuable time
Thanks...
Green4ever...
5. Re: Placing grouped library element in anchor
Marijan Tompa Aug 14, 2010 1:24 PM (in response to Green4ever)Hey!
You can address your library by it's name, so then you can have more than one opened libraries.
var Lib = app.libraries.itemByName("/*lib_name_with_extension*/");--
tomaxxi
