9.0.1 upgrade breaks getDataSourceService
Aug 13, 2010 Aug 13, 2010
This code has worked fine in versions 7.x to 9.x.
<cfset factory      = createobject("java", "coldfusion.server.ServiceFactory")>
<cfset service      = factory.getDataSourceService()>
<cfset datasources  = service.getDataSources()>
Now in 9.0.1 it errors on the last command with a generic "Error processing request" message.  The exception.log shows:
"Error","jrpp-148","08/13/10","08:32:16",,"'' The specific sequence of files included or processed is: E:\Inetpub\wwwroot\....., line: 32 "
coldfusion.security.SecurityManager$UnauthenticatedCredentialsException
    at coldfusion.security.SecurityManager.authenticateAdmin(SecurityManager.java:1958)
    at coldfusion.sql.Executive.getDatasources(Executive.java:96)
It appears to be related to security, most likely checking for Administrator privilege.  Any one have any ideas how to get around this?  Thanks.
Michael
Advanced techniques
1.6K
Advocate ,
Try executing the login() method of cfide.adminapi.administrator first.
Good suggestion but I just tried it and it did not make a difference. The adminapi object is unrelated to the serviceFactory object so it does not see that the session is authenticated.  I tried creating a coldfusion.server.ServiceFactory.getSecurityService() object and dumping it to see the methods. There is a method called authenticateAdmin( ) but that also generates the same exception.
Advocate ,
Then I suggest you rewrite it to use the getDatasources() method of CFIDE.adminapi.datasource.
I was not aware of that API call and I just did a quick test and it looks like it will work.  Thanks!
Michael
Advocate ,
And the good thing about that API is that it is supported: if it breaks
from one version to the next you can file a bug. The internal stuff is
all "use at your own risk".
Documentation
