Hi all!
One of the most common feedback items we've seen is the lack
of a progress bar to let the student know how much of the
presentation is left. Sure, there's a bar when the viewer is in the
"tabbed" view, but the "time remaining" listed there is usually WAY
off if you're letting the student advance through the presentation
at their own pace. We set out to make a self-contained progress bar
in Flash that could be dropped into any PPT presentation and would
provide the student with a simple indication of how far along they
are. Here's how to make one yourself :
First, your progress module has to have at least two frames.
This is because your module will need to read data from the
"viewer.swf" application that shows the Breeze presentation, and
that information is apparently not read in until all the actions on
frame one of every module present are done. So the actionscript for
frame 1 of our module is simply:
this.gotoAndStop(2);
Next, we're indicating progress by how long a bar is -
namely, modifying the
_width property of a movieclip instance. Our movieclip in
the library was just a green rectangle, and our instance of that
was named
progress_mc, with a default width of 285 pixels. Make sure
that the bar is aligned with the left & center of the stage in
the movieclip in your library, so that it will grow and shrink
correctly.
Now that the bar is set up and ready to manipulate, here's
the code we placed on frame 2:
var mySlideNumber =
_root.m_contentView.m_currentSlide.indexInTOC + 1;
var myLastSlide = _root.m_viewerController.m_slides.length;
var myIncrement = 285 / myLastSlide; //285 pixels is the
default width of the movieclip instance
progress_mc._width = (myIncrement * mySlideNumber);
_root.m_sidebarView.m_elapsedBar._visible = false; // this
hides the incorrect "time remaining" bar
...and that's all it took! Of course, the one we're using now
is a little fancier in terms of graphics, and tailor-sized for our
templates, but the code is virtually identical. I can give the
"progress bar.swf" module to anyone for inclusion in their PPT
slides, and it will work perfectly when they compile their Breeze
presentation. The only annoyance is that you have to paste one on
every slide (that you want indication on), rather than putting one
on the slide master. But, this is still FAR easier than
hand-crafting progress bars for every presentation.
Cheers!
~Marc B
