2 Replies Latest reply: Sep 19, 2011 11:06 AM by egyhots1 RSS
    tabindex + highlight
    gabi_poa
      Hi there.
      I actually have two questions:
      • tabIndex is based on what? See this code
      counter++;
      var cre = _root.attachMovie("creditos", "creditos", counter);
      counter++;
      var sai = _root.attachMovie("sair", "sair", counter);
      counter++;
      var jog = _root.attachMovie("jogar", "jogar", counter);
      jog.tabIndex=0
      cre.tabIndex=1
      sai.tabIndex=2
      But it always start from "cre" button.
      • can I highlight a button? i want to start the swf with that button on the "over" state, so if the user presses enter it would trigger its click function. PS. I set the focusrect to false.
      Thanks in advance
        • 1. Re: tabindex + highlight
          chall3ng3r Community Member
          You can use Selection.setFocus("path") function for this. For example,
          Selection.setFocus("cre");
          I have found that tabIndex doesn't work correctly in FL, specifically for text fields. However, I managed to make my own focusmanager using Selection.setFocus function.
          Hope it helps,
          // chall3ng3r //
          • 2. Re: tabindex + highlight
            egyhots1
            I have several input textfields that are TAB-enabled. The problem I'm having is that when TAB is pressed, it highlights the textfield with an obnoxious yellow/green border. Does anybody know how to get rid of this? My AS is below:
            //enable tabbing
            user_input.tabEnabled = true;
            pword_input.tabEnabled = true;
            pword_confirm.tabEnabled = true;
            user_input.tabIndex = 1;
            pword_input.tabIndex = 2;
            pword_confirm.tabIndex = 3;
            //disable rect
            user_input._focusrect = false;
            pword_input._focusrect = false;
            pword_confirm._focusrect = false;
            Thanks in advance for any help/hints you can give me
            ــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــ ــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــ ـــــــــــــــــــــــــــــــــــــــــــــــــــ
            mtv50
