I've got a batch script that runs an ant script that executes
"cvs log -h application.cfm" on the cvs server.
When I execute the batch script manually on the command line,
everything works fine.
When I execute the batch script via CFEXECUTE, the batch
works fine, the ant script works fine, but the cvs command doesn't
appear to do anything. The results from the tag are:
[echo] before
[echo] after
As you'll see from the attached ant script (unchanged except
for the cvsroot attribute), those echos are either side of the cvs
command.
When running via the command line, I get the results from the
cvs log command in between those lines, but with CF I get nothing.
Any ideas at all on how to get this working will be greatly
appreciated.
