0 Replies Latest reply on Aug 18, 2010 6:08 PM by DougBanks
    Running FlexUnit tests from command line
      Sorry if that has been posted before: I searched best I could and nothing came up.
      I am interested in building and running my unit tests from the command line so we can add it to a nightly build process.
      I am *very* new to all this: basically I picked up Adobe Flash Builder 4 a month ago and I have done *everything* inside that IDE: writing code, building, testing, running.
      I looked into at least how to build something from the command line, I found this:
      http://help.adobe.com/en_US/flashbuilder/using/WSbde04e3d3e6474c4-59108b2e1215eb9d5e4-8000 .html
      Can't get past this error:
      Buildfile: /Users/dbanks/build_test.xml
      Target "FlexUnitApplication" does not exist in the project "null".
      Total time: 0 seconds
      Adobe Flash Builder 4:
      An error has occurred. See the log file
      /Users/dbanks/Documents/Adobe Flash Builder 4/.metadata/.log.
      Plus, even if I got this going, I am just building the swf.  I also want to run it and capture the output in some meaningful way that can be read/evaluated/acted on.
      FWIW, the script/xml I am using to try to build:
      <?xml version="1.0"?>
      <project default="main">
          <target name="main">
              <fb.exportReleaseBuild project="NightclubMogul" />
      # works with either FlashBuilder.app or Eclipse.app
      "/Applications/AdobeFlashBuilder4" \
          --launcher.suppressErrors   \
          -noSplash   \
          -application org.eclipse.ant.core.antRunner   \
          -data "$WORKSPACE"    \
          -file "/Users/dbanks/build_test.xml" FlexUnitApplication
      I am not clear what in here is actually supposed to point to where my project lives: it's off in some directory somewhere.  I see that I am pointing to a workspace (Documents/AdobeFlashBuilder4) but when I poke around in there I don't see anything connecting back to the directories where the code lives.
      Any help would be great: getting the tests to build from command line, then getting them to run.
