Workspace in use or Cannot be Created
Apr 02, 2010 Apr 02, 2010
Is it possible to setup CFBuilder so files opened in Windows explorer open in the currently open instance.  The final release tries to spawn a new instance and displays "Workspace in use or Cannot be Created".  I got around this in Beta's but i can't find a workaround in the final release.
Builder
12.7K
As it happens I asked this very question on another forum just yesterday, and the answer came through forthwith.
If you have a look in your home directory, there'll be a subdirectory ".eclipse".  Delete it, and start CFB with the -clean parameter, and that should sort it out.
Works on OS/X, Win7 (according to the person who pointed me in the right direction for this) & Win Vista (my own environment).
HTH.
Adam
Apr 07, 2010 Apr 07, 2010
NB: does not work on Windows7 (Starter Ed.) for me.
Adam
Thanks Adam it does not seem to work for me on WIN7 Home Premium for me. Also are you using a standalone or plugin install?
  George S.
Stand-alone.
Adam
Jun 05, 2010 Jun 05, 2010
I've created http://cfbugs.adobe.com/bugreport/flexbugui/cfbugtracker/main.html#bugId=83269 for this.
Adam
Thanks Adam it actually fixed in the last patch, so make sure to get the patch.  On the same note, i completely abandoded that piece of #$## in favor cfEclipse and notepad++, they actually work and don't freeze every 5 minutes.
It still doesn't work for me on Vista Business (or Pro, or whatever it is... I'm not in front of that PC right now).
So it's still not [properly] fixed.
Adam
Jul 21, 2010 Jul 21, 2010
I THINK I've got a workaround for this utterly annoying problem (or, it just gave up and came good, still worth a try if you're having this issue)
My CF Builder is installed as plugin to  FlashBuilder 4 on Win 7.  I got the same as described, and spent ages looking for a lock file or something.
Finally, in File/Switch Workspace/Other.. with the default workspace selected in the drop down (the one that was giving this error when I attempted to open it),  under the Copy Settings check boxes (expanded), I selected both options (Workbench Layout and Working Sets),  then clicked OK.  This loaded the workspace, sort of, in that colour coding and code completion etc wasn't working.  I closed and restarted Flash Builder, and it now seems to be OK again.
Peter Robertson
Jul 26, 2010 Jul 26, 2010
Thanks for the response have you updated to latest version, for me update 1 has resolved this issue [http://www.adrocknaphobia.com/post.cfm/coldfusion-builder-update-1-available].
It didn't fix it for me.
Adam
Yes Adam, I had meant to re-post, and in fact in the end it hadn't fixed it
for me either. It remained flaky and then I lost CF support (code
completion colour coding, etc). I ripped the whole thing out and
clean-reinstalled, which is what I should have done in the beginning and I
would have saved a lot of time.
Cheers
Peter
Hi. When you updated you effectively re-installed I suppose? This is
probably what fixed your issue, and yes, I have the latest version. In the
end what I thought was a fix wasn't, and I wasted a lot of time messing
around. If it happens again, then I'm just going to bite the bullet and
cleanly re-install straight up.
Cheers
Peter
Further to my previous post, (July 22), within a hour or so I had lost CF support again, and did a clean re-install to get back to work.  One thing I should mention is that the issue seemed to occur when I was trying to open a project on resources that weren't available, (a VM server I had forgotten to start before opening CF Builder).  On previous occasions, this had caused a similar issue, but a re-start had cleared it.  This time, nothing I could do got the workspace back.
Peter
Jul 27, 2010 Jul 27, 2010
This same thing happened again today, just a few days after the previously-reported event.
It was immediately after accepting an Adobe update to CFBuilder.
My workspace was not available, exactly as reported above.
I shut Flash Builder down and re-started as Admin (Win 7).
My workspace was available as per normal.
I shut down and re-started Flash Builder as a normal user it was fine.
My last test was to re-boot my machine, which I did, and I was able to start builder as a normal user and it was ok
While I'm happy to be back in business, this behavior worries me, especially considering that I wasn't able to recover on the previous occasion without a re-install.  CF Builder is my core professional tool, and I simply can't afford to be prevented from working on some random basis.  I hope Adobe folk are attending to this issue.
Peter Robertson
Guest
Peter,
After updating CFBuilder, did you restart builder with a clean option?
Sagar.
Hi Sagar
Do you mean did I un-install CF Builder first? Otherwise, I'm not sure what
you mean by a 'clean option'.
At this point things are working, I cleared the problem last time by
starting Flash Builder once with admin rights (or, it seemed that this
cleared it, or it just came good, who knows?)
Peter
Guest
Peter,
I was referring to the updating CFBuilder i.e. after applying the updater for CFB you are required to start CFB with a clean option. Please see http://kb2.adobe.com/cps/846/cpsid_84607.html.
Sagar.
Ah yes, I recall seeing that, but thought it only applied to upgrades from a
beta, didn't know it applied to release code. Also, I did use "*You can
also install ColdFusion Builder Update 1 using Adobe Updater that appears in
the system tray.", *which asks for admin rights, so assumed that applied the
script. Anyway, will keep this in mind if it occurs again, and thanks for
the clarification.
Regards
Peter
Aug 06, 2010 Aug 06, 2010
I will also pipe in and state that this is something that I have seen a few times, more
so on Windows 7 than any other version of Windows.
The problem is that there are times when you think you have closed ColdFusion Builder / Eclipse down, that it in fact is still actually running.
So when you go and try to use the same workspace you are presented with the message that it is in use or cannot be created.
The solution is simple, if this is the case with people then it is just a matter of killing that instance of Eclipse that is still running.
Andrew Scott
http://www.andyscott.id.au
Hi Andrew.
Yep, that's what I would have thought.  Not only did killing Eclipse not solve the issue, re-starting the Win 7 box didn't either, so the lock, where ever it is, was persisted.  From memory, the last time this occurred, (some short time after re-installing Flash Builder / CF Builder), I re-started FB as Admin and this seemed to solve the issue.  I can't swear to this, it was a little while ago.
It's worth mentioning that my setup may be contributing to this.  I'm working on a client job which involves running a Win XP instance in a VM.  I connect to this from the host via a mapped drive to a share inside the VM.  FB does have issues if I have a project open on the VM filespace and forget to close my dev environment on the host prior to shutting down the VM instance.  Understandable that this is a problem, but not very robust if this locks up the workspace in such a way that I can't access any projects (including to the host file space).
Cheers
Peter
Aug 18, 2010 Aug 18, 2010
Hmmm the whole cannot open workspace came back for me out of the nowhere, after a going away post-update, i rebuilt my workspace and did -clean start as admin, i no longer get the whole Workspace is in use message but the file does not open either. I sure would like a refund.
That's frustrating! I haven't had a recurrence so far, but I live in fear.
I do recall starting FlashBuilder (which is my base-install for CF
Builer) as Admin at some time, but can't recall what else I did, or if
this simply somehow cleared the problem. The cause when this did
occur seemed to be closing a VM OS instance while CF Builder had a
project open on the vm filespace. Whenever I forgot to close the
project before shutting down the vm, I got into trouble. Since the
update, (and whatever else I did), I have repeated this sequence
(through forgetting to be careful), and on re-start, have been able to
open the workspace. This gives me anxious moments until I see
everything load OK.
I'm sorry you're still having trouble, that is very fragile behaviour.
Regards
Peter
Aug 27, 2011 Aug 27, 2011
On a related note....sorry just realized the OP was trying to solve a slightly different problem...
If you run into the "Workspace in use or cannot be created" due to an eclipse crash, this should get you out of the bind:
1) Ensure that the eclipse processes are really gone.
I killed everything that had java and eclipse (scorched earth policy 😉  YMMV) before I got this workaround to work
You won't need to do this if you've rebooted since the failure started to occur
2) Delete the lock  file: <path to eclipse workspace>/.metadata/.lock
3) Restart eclipse 😉
4) Happy coding
Dec 28, 2012 Dec 28, 2012
Syndrome: FlashBuilder 4.6 refuses to access your workspace under Windows7, even after deleting the
lock file (.metadata/.lock).
Solution:
1. Click "Cancel" when prompted to select a different workspace (doing so wouldn't get you nowhere, anyway);
2. Start FlashBuilder with administrator rights. This will, in fact create a new workspace to start in.
3. Go to the "File" menu, select "Switch Workspace", select "Other", type the correct path to your workspace,
   expand "Copy Settings", tick both checkboxes, click "OK".
4. Wait until the other workspace loads.
5. Exit Flash Builder, wait until processes end, and start it anew, WITHOUT administrator rights. It should
   work now. You may delete now the new workspace Flash Builder has created when started with administrator
   rights.
Note: This may or may not work, since, well, it's Adobe software 😞
Documentation
