3 Replies Latest reply on Aug 19, 2010 5:55 AM by Harm Millaard
    Install error
    mollymoomoo89 Level 1
      Hi I've been trying to install Adobe Premiere Pro CS5 for a long time now, trying various different things to get it to install but its just not working. I keep getting this error log:
      Exit Code: 7
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 66 error(s), 70 warning(s)
      WARNING: OS requirements not met for {33A3F995-8333-4676-8D6F-AB7674BB52EA}
      WARNING: OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
      WARNING: Warning: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 will not be repaired. Only language packs will be installed for it.
      WARNING: Warning: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 will not be repaired. Only language packs will be installed for it.
      WARNING: Payload cannot be installed due to dependent operation failure
      ERROR: The following payload errors were found during install:
      ERROR:  - Adobe OnLocation CS5 Royalty Content Wrapper: Install failed
      ERROR:  - Adobe CSXS Infrastructure CS5: Install failed
      ERROR:  - Microsoft_VC90_ATL_x86: Install failed
      ERROR:  - Adobe Media Player: Install failed
      ERROR:  - SiteCatalyst NetAverages: Install failed
      ERROR:  - Adobe Bridge CS5: Install failed
      ERROR:  - Microsoft_VC80_ATL_x86: Install failed
      ERROR:  - Recommended Common Fonts Installation x64: Install failed
      ERROR:  - AdobePDFL x64 CS5: Install failed
      ERROR:  - Adobe Encore CS5 Royalty Codecs Installer Wrapper: Install failed
      ERROR:  - DeviceCentral_DeviceCentral3LP-en_GB: Install failed
      ERROR:  - Microsoft_VC80_MFCLOC_x86_x64: Install failed
      ERROR:  - Adobe Premiere Pro CS5 Third Party Content Wrapper: Install failed
      ERROR:  - Adobe XMP Panels CS5: Install failed
      ERROR:  - Adobe Player for Embedding: Install failed
      ERROR:  - Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack: Install failed
      ERROR:  - Photoshop Camera Raw: Install failed
      ERROR:  - AdobeHelp: Install failed
      ERROR:  - Camera Profiles Installer: Install failed
      ERROR:  - Adobe Mini Bridge CS5: Install failed
      ERROR:  - Microsoft_VC80_CRT_x86_x64: Install failed
      ERROR:  - Adobe ReviewPanel CS5: Install failed
      ERROR:  - Adobe BrowserLab CS Live: Install failed
      ERROR:  - Photoshop Camera Raw (64 bit): Install failed
      ERROR:  - Microsoft_VC90_MFC_x86: Install failed
      ERROR:  - CSXS Story Extension: Install failed
      ERROR:  - Adobe Media Encoder CS5 X64: Install failed
      ERROR:  - Suite Shared Configuration CS5: Install failed
      ERROR:  - Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper: Install failed
      ERROR:  - DeviceCentral: Failed due to Language Pack installation failure
      ERROR:  - AdobeTypeSupport CS5: Install failed
      ERROR:  - Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack: Install failed
      ERROR:  - Adobe Player for Embedding x64: Install failed
      ERROR:  - Required Common Fonts Installation x64: Install failed
      ERROR:  - Microsoft_VC90_ATL_x86_x64: Install failed
      ERROR:  - Adobe CSXS Extensions CS5: Install failed
      ERROR:  - AdobeOutputModule: Install failed
      ERROR:  - Microsoft_VC90_CRT_x86_x64: Install failed
      ERROR:  - Adobe Premiere Pro CS5 Family: Install failed
      ERROR:  - AdobeCMaps x64 CS5: Install failed
      ERROR:  - AdobeTypeSupport x64 CS5: Install failed
      ERROR:  - Adobe Media Encoder CS5 PCI WRAPPER X64: Install failed
      ERROR:  - Adobe Encore CS5: Failed due to Language Pack installation failure
      ERROR:  - Microsoft_VC90_MFC_x86_x64: Install failed
      ERROR:  - DynamiclinkSupport: Install failed
      ERROR:  - Adobe OnLocation CS5: Failed due to Language Pack installation failure
      ERROR:  - Adobe Encore CS5_AdobeEncore5en_USLanguagePack: Install failed
      ERROR:  - AdobePDFL CS5: Install failed
      ERROR:  - HIL Help Search: Install failed
      ERROR:  - AdobeCMaps CS5: Install failed
      ERROR:  - Adobe Premiere Pro CS5: Failed due to Language Pack installation failure
      ERROR:  - Microsoft_VC80_MFC_x86_x64: Install failed
      ERROR:  - ph: Install failed
      ERROR:  - Required Common Fonts Installation: Install failed
      ERROR:  - AmericanEnglishSpeechAnalysisModels: Install failed
      ERROR:  - Adobe SwitchBoard 2.0: Install failed
      ERROR:  - Microsoft_VC80_MFC_x86: Install failed
      ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
      ERROR:  - Recommended Common Fonts Installation: Install failed
      ERROR:  - Adobe Extension Manager CS5: Install failed
      ERROR:  - AdobeJRE: Install failed
      ERROR:  - Adobe ExtendScript Toolkit CS5: Install failed
      ERROR:  - Adobe AIR: Install failed
      ERROR:  - Adobe Premiere Pro CS5 Support: Install failed
      ERROR:  - Adobe Media Encoder CS5 Dolby WRAPPER X64: Install failed
      Any idea what the problem is?
      Here's my System Information, just in case it may be needed to solve this error:
      OS Name    Microsoft Windows 7 Home Premium
      Version    6.1.7600 Build 7600
      Other OS Description     Not Available
      OS Manufacturer    Microsoft Corporation
      System Manufacturer    HP-Pavilion
      System Model    WC873AA-ABU p6300uk
      System Type    x64-based PC
      Processor    AMD Athlon(tm) II X2 215 Processor, 2700 Mhz, 2 Core(s), 2 Logical Processor(s)
      Installed Physical Memory (RAM)    3.00 GB
      Total Physical Memory    2.75 GB
      Available Physical Memory    1.51 GB
      Total Virtual Memory    5.50 GB
      Available Virtual Memory    3.66 GB
      Page File Space    2.75 GB
      Thanks in advance for any help given.
