I am having some difficulty returning values checked for null.
The Javascript function is Calculate and my code is as follows:
if (xfa.resolveNode("INPUT.Vehicle.Row[0].Vehicle-Year").rawValue != null) {
(xfa.resolveNode("INPUT.Vehicle.Row[0].Vehicle-Year").rawValue + " ");
} else {
if (xfa.resolveNode("INPUT.Vehicle.Row[0].Vehicle-Make").rawValue != null) {
(xfa.resolveNode("INPUT.Vehicle.Row[0].Vehicle-Make").rawValue + " ");
} else {
if (xfa.resolveNode("INPUT.Vehicle.Row[1].Vehicle-Model").rawValue != null) {
(xfa.resolveNode("INPUT.Vehicle.Row[1].Vehicle-Model").rawValue + " - ");
} else {
if (xfa.resolveNode("INPUT.Vehicle.Row[2].Vehicle-Colour").rawValue != null) {
(xfa.resolveNode("INPUT.Vehicle.Row[2].Vehicle-Colour").rawValue);
} else {
The initial value is not null returns properly, however, any subsequent value will override previous values and return the last not null field value.
Please help...
Solved! Go to Solution.
Total Likes
Try the following code.. See if it helps.
var strVehicleYear, strVehicleMake, strVehicleModel, strVehicleColour
strVehicleYear = xfa.resolveNode("INPUT.Vehicle.Row[0].Vehicle-Year").rawValue + " ";
else
strVehicleYear = "";
strVehicleMake = xfa.resolveNode("INPUT.Vehicle.Row[0].Vehicle-Make").rawValue + " ";
else
strVehicleMake = "";
strVehicleModel = xfa.resolveNode("INPUT.Vehicle.Row[1].Vehicle-Model").rawValue + "-";
else
strVehicleModel = "";
strVehicleColour = xfa.resolveNode("INPUT.Vehicle.Row[2].Vehicle-Colour").rawValue;
else
strVehicleColour = "";
this.rawValue = strVehicleYear + strVehicleMake + strVehicleModel + strVehicleColour;
Srini
Total Likes
Try '== null' or 'is null'
Total Likes
Nope, and I was wrong with the "+" signs as when they are there no values are returned.
Without the "+" signs as follows:
} else {
} else {
} else {
} else {
I don't then get the "Null" value within the concatenated field, however, only the last value which is not null shows in this field.
How do I attach all the fields together?
Total Likes
else
else
else
else
Srini
Total Likes
Helps?
IT'S PERFECT!!
Thank you.
Total Likes
