I have generated a Soap Webservice in Flashbuilder and need to add A Soap Header with 3 variables.
Can anyone tell me how this is done?
http://livedocs.adobe.com/flex/3/langref/mx/rpc/soap/AbstractWebService.html#addHeader()
addHeader(header:Object):void
This adds to the headers:Array member of the WebService Class.
The header object is to be queued as header[headerName]=headerValue.
It is preferable however that you create a SoapHeader object, whose constructor takes a qname:QName and content:Object as arguments and constructs the header
You may also use the addSimpleHeader(qnameLocal:String,qnameNamespace:String,headerName:String,headerValue:String):void method.
This creates a SoapHeader object, whose QName is constructed from the Local and Namespace Strings and a content object with the headerValue keyed on the headerName property.
Hope this helps,
Balakrishnan V
Hello,
Thanx for yor response...
However i am a newbee in this matter.
Here is my code, can you look at it fill in the blancs, correct it?
* This is a generated class and is not intended for modification. To customize behavior
* of this service wrapper you may modify the generated sub-class of this class - Ticketunie.as.
package server.services.ticketunie
import com.adobe.fiber.core.model_internal;
import com.adobe.fiber.services.wrapper.WebServiceWrapper;
import com.adobe.serializers.utility.TypeUtility;
import mx.rpc.AbstractOperation;
import mx.rpc.AsyncToken;
import mx.rpc.soap.mxml.Operation;
import mx.rpc.soap.mxml.WebService;
import mx.rpc.soap.SOAPHeader;
[ExcludeClass]
internal class _Super_Ticketunie extends com.adobe.fiber.services.wrapper.WebServiceWrapper
// Constructor
public function _Super_Ticketunie()
// initialize service control
_serviceControl = new mx.rpc.soap.mxml.WebService();
var operations:Object = new Object();
var operation:mx.rpc.soap.mxml.Operation;
operation = new mx.rpc.soap.mxml.Operation(null, "HelloWorldAuth");
operation.resultType = String;
operations["HelloWorldAuth"] = operation;
_serviceControl.operations = operations;
try
_serviceControl.convertResultHandler = com.adobe.serializers.utility.TypeUtility.convertResultHandler;
catch (e: Error)
{ /* Flex 3.4 and eralier does not support the convertResultHandler functionality. */ }
_serviceControl.service = "Service";
_serviceControl.port = "ServiceSoap";
wsdl = "http://secure.ticketunie.com/iresWs/service.asmx?WSDL";
model_internal::loadWSDLIfNecessary();
model_internal::initialize();
public var header1:SOAPHeader;
public var header2:SOAPHeader;
public var header3:SOAPHeader;
public function headers():void {
// Create QName and SOAPHeader objects.
var q1:QName=new QName("http://soapinterop.org/xsd", "Header1");
header1=new SOAPHeader(q1, {string:"Trsid",int:"value1"});
header2=new SOAPHeader(q1, {string:"Coho",int:"value2"});
header3=new SOAPHeader(q1, {string:"Key",string:"value3"});
// Add the header1 SOAP Header to all web service request.
???.addHeader(header1);
???.addHeader(header2);
???.addHeader(header3);
* This method is a generated wrapper used to call the 'HelloWorldAuth' operation. It returns an mx.rpc.AsyncToken whose
* result property will be populated with the result of the operation when the server response is received.
* To use this result from MXML code, define a CallResponder component and assign its token property to this method's return value.
* You can then bind to CallResponder.lastResult or listen for the CallResponder.result or fault events.
* @see mx.rpc.AsyncToken
* @see mx.rpc.CallResponder
* @return an mx.rpc.AsyncToken whose result property will be populated with the result of the operation when the server response is received.
public function HelloWorldAuth() : mx.rpc.AsyncToken
var _internal_operation:mx.rpc.AbstractOperation = _serviceControl.getOperation("HelloWorldAuth");
var _internal_token:mx.rpc.AsyncToken = _internal_operation.send() ;
return _internal_token;
http://livedocs.adobe.com/flex/3/langref/mx/rpc/soap/Operation.html#addHeader()
The operation can also add an header.
Use the appropriate operation to which you want to add the header.
Here, "operation" or "operations["HelloWorldAuth"] can be used
operations["HelloWorldAuth"].addHeader();
This should work !(I have not tried it out though !)
Try it and tell me if it works
balakrishnan v
I've tried this, but it did not work. I get a response value
of -4, should be 1.
Hre is my code again (tried operations["HelloWorldAuth"].addHeader(); also).
import mx.rpc.soap.Operation;
[ExcludeClass]
// Constructor
try
catch (e: Error)
var q1:QName=new QName("http://secure.ticketunie.com/", "Header1");
header1=new SOAPHeader(q1, {string:"Trsid",int:"299"});
header2=new SOAPHeader(q1, {string:"Coho",int:"1"});
header3=new SOAPHeader(q1, {string:"Key",string:"70db3164e4421b33bd9f170db3164e4421b33bd9f1"});
operations.addHeader(header1);
operations.addHeader(header2);
operations.addHeader(header3);
Solved the problem...
Could I know what you did to solve the issue ? It might be helpful for the forum to have a record of the solution as well !
Balakrishnan V
Hello,
The key was putting the soapheader variables in an object...
var obj:Object=new Object();
obj.headerName1 = value1;
obj.headerName2 = value2;
obj.headerName3 = "value3";
var qname:QName=new QName("http://secure.website.com/",
"AuthenticationHeader");
var header1:SOAPHeader = new SOAPHeader(qname, obj);
operations["certainCall"].addHeader(header1);
I shall post the solution in the forum...
Met vriendelijke groeten, Dik Hendriks
Hendriks grafische vormgeving / webdesign
(038) 332 49 79
Dit e-mail-bericht is alleen bestemd voor de geadresseerde(n). Indien
dit bericht niet voor u is bedoeld, wordt u verzocht de afzender
hiervan op de hoogte te stellen door het bericht te retourneren en
de inhoud niet te gebruiken. Aan dit bericht kunnen geen rechten
worden ontleend.
Op 25 aug 2010, om 05:16 heeft Balakrishnan V het volgende geschreven:
Balakrishnan V
var qname:QName=new QName("http://secure.website.com/", "AuthenticationHeader");
