<input> with regular expression
Guest
May 12, 2006 May 12, 2006
I am wondering how to use the _regex in a hidden <input>. i have searched every where but there is no examples on how to use this cfml form validation. Its not that i want alternatives to do the regular expression just how to use it like this......
if i had the form....
<form.........>
<input name="email">
<input type="hidden" name="email_regex" value="*/.............">
</form>
How can i have a message if the input email does not coincide with the regular expression. would i need to use a second
<input type="hidden" name="email_regex_Required" value="please insert a valid email adress>
Advanced techniques
807
Participant ,
Sounds like you need to use javascript (JS). CF doesn't know the value if the 'email' field until you've submitted the form.
Of course JS can work with CF vars too so assuming the hidden field contains a CF var, send the form to a JS function to compare the 2 fields when you submit. Then submit the form or return the error accordingly..
Jam
Guest
i am trying to get it to work like this. The validation type is valid but i have not found anything on how to use it properly.
it like using the
<input type="hidden" name="email_required" value="the field is blank, please go back and enter a filed">
I know javascript is the best option but if the browser does not support this then at least in can attempt a alternative method. All i would like to know is how do i use this validation type and how can i get it also to produse a error message. as the "value" field will contain the regular expresion itself.
Guest
it like using the
Participant ,
To use cf validation you need a CFFORM and CFINPUT field.
<cfinput name="email" type="Text" required="Yes" message="the field is blank, please go back and enter a filed">
Can you post the actual code from the page please and then explain at what point the hidden field is populated?
Participant ,
Guest
sorry my mistake the it is _cfformregex _cfformregular_expression. how do you use these........
http://livedocs.macromedia.com/coldfusion/7/htmldocs/wwhelp/wwhimpl/common/html/wwhelp.htm?context=C...
Participant ,
<cfinput type="Text"
name="email"
message="Valid email address required..."
validate="Regular_expression"
required="Yes"
pattern="your_REGEXP">
Guest
this is a cfinput though. it is also possible to do this in an input and this is what i am trying to understand how to use........
http://livedocs.macromedia.com/coldfusion/7/htmldocs/00001385.htm#1154690
Participant ,
May 15, 2006 May 15, 2006
Hi - Been away!
If you're still looking at this - I think you want to use the (MX7) form validation on standard html and form elements:
(I think) MX7 is like this:
<input type="hidden" name="emailAdress_ cfformregex" value="your_reg_exp">
<!--- I think you have to add another hidden field if you want to make it mandatory...
<input type="Hidden" name="emailddress_required" value="Email address is required...">
<input type="Text" name="emailddress">
but you'll have to experiment...
Documentation
