"SwitchBoard Server (32-bit) has stopped working" Bridge CS5
Guest
Jun 29, 2010 Jun 29, 2010
I installed Design Premium CS5 last week and tried Bridge today. It worked fine and then suddenly whenever I open it, I keep getting this window. I close the window, but it appears again after a few seconds. I can still use Bridge, but the window won't go away.
49.3K
Jun 30, 2010 Jun 30, 2010
The switchboard server process provides communication between Bridge and Mini Bridge (in Photoshop, InDesign and InCopy). The switchboard server launches when you launch Bridge and runs in the background. It sounds like this process keeps trying to start, then crashes. What Windows OS are you running and is it 32bit or 64bit? Once I find that out, I'll get you some information on where to find a crash log that you can send.
Julie Manley
Adobe
Guest
I'm using Windows 7 Pro on a 64-bit machine.
Adobe Employee ,
Jul 02, 2010 Jul 02, 2010
Please try a few things in the following,
- Try launching switchboard.exe directly (located in \Program Files (x86)\Common Files\Adobe\Switchboard). On a working system, switchboard should launch, run for a few seconds, then exit (since it has no connection to Bridge or Mini Bridge, please use "Windows Task Manager"->Processes to monitor this).
- Try deleting the switchboard.ini file (located in \Users\<username>\AppData\Roaming\Adobe\Switchboard), then launch switchboard.exe manually again. This should regenerate the ini file.
- Check the contents of the switchboard.ini file - it should contain 5 values:
MD5=Alphanumeric value
USERID=Alphanumeric value
SWITCHBOARD=Alphanumeric value
PORT=3705
SERVER=path to Switchboard.exe
(See tech note http://kb2.adobe.com/cps/830/cpsid_83045.html if the MD5 or USERID values are missing.)
- Check the user's hosts file (a default hosts file can be found here:http://support.microsoft.com/kb/972034)
- Try creating a new user account, log into the new account and try running Bridge to see if switchboard still crashes.
Guest
Jul 12, 2010 Jul 12, 2010
Thanks for the reply. I tried all of these things and still get the same error message when using the new user account and my normal user account. What should I try next?
Guest
I've found that if I close the error message about 5 or 6 times, Bridge finally catalogs everything and works just fine. The error message doesn't come up again until the next time I open Bridge. It's a problem I can live with, but my concern is that it indicates that something is not right with my system or with my copy of Bridge.
Jul 15, 2010 Jul 15, 2010
I'm having the exact same problem. It usually takes 4 times telling the windows message to "stop the program" for Bridge to remember and stop popping it up. I'm using a Dell Precision M4400 with 4GB RAM. So yeah, I'd love to hear of a solution that works!
Guest
Aug 21, 2010 Aug 21, 2010
This is so frustrating. I got support from Adobe for a while. My case was opened on July 14. But since July 27, the status has been: "Open pending  Adobe response." They just stopped communicating with me. No explanation.  I've sent three messages since then asking for some communication, even just to let me know that there's nothing they can do.
I did everything they suggested and answered all of their questions. Nothing helped. Perhaps they've started hiring former Dell employees to run their customer support.
Aug 24, 2010 Aug 24, 2010
I am having a problem with the switchboard server on an XP/sp3 system as well.Since the switchboard server is not loading correctly, mini-bridge will sit waiting for CS 5 Bridge forever.However, Mini-Bridge still does start correctly if Bridge was started previously. I think I know why, but do not know how to fix it.
The Adobe Switchboard service is suppose to load which leads to a switchboard process being loaded. The switchboard service does not load (error information below) and the switchboard.exe process is not started in the Windows XP run list when one logs on. Hence, mini-bridge has no switchboard to use to start bridge.
However, if one starts Bridge first (even if one closes and exits bridge) the switchboard.exe process is started by Bridge. After that, mini-Bridge works correctly.
I have attempted to start the process from a command window, but nothing happens and no event is recorded.
C:\Program Files\Common Files\Adobe\SwitchBoard>dir
Volume in drive C has no label.
Volume Serial Number is 88E4-EDB7
Directory of C:\Program Files\Common Files\Adobe\SwitchBoard
07/28/2010  03:26 PM    <DIR>          .
07/28/2010  03:26 PM    <DIR>          ..
02/19/2010  01:37 PM           422,400 adobe_caps.dll
07/28/2010  03:26 PM    <DIR>          AMT
07/28/2010  03:26 PM    <DIR>          Legal
02/19/2010  01:37 PM           517,096 SwitchBoard.exe
02/19/2010  01:37 PM            30,489 SwitchBoard.pdf
               3 File(s)        969,985 bytes
               4 Dir(s)  84,354,781,184 bytes free
C:\Program Files\Common Files\Adobe\SwitchBoard>switchboard.exe
So Bridge can start the process but I cannot (even with an administrative account).
The following is the error information about the Adobe Switchboard service error:
Event Type: Error
Event Source: Service Control Manager
Event Category: None
Event ID: 7009
Date:  8/24/2010
Time:  4:29:05 PM
User:  N/A
Computer: MAINXP
Description:
Timeout (30000 milliseconds) waiting for the Adobe SwitchBoard service to connect.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Event Type: Error
Event ID: 7000
Date:  8/24/2010
Time:  4:29:05 PM
User:  N/A
Computer: MAINXP
Description:
The Adobe SwitchBoard service failed to start due to the following error:
The service did not respond to the start or control request in a timely fashion.
sc query Adobe SwitchBoard
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\testuser>sc query Adobe SwitchBoard
[SC] EnumQueryServicesStatus:OpenService FAILED 1060:
The specified service does not exist as an installed service.
These types of errors are happening with other users, but the causes vary with the OS being used.
Ideas?
Guest
Aug 28, 2010 Aug 28, 2010
@MikeV99, I don't know if you have an active support case on this with Adobe, but if you do and you get an answer from Adobe (or any response at all, for that matter) please post it here. I'm still waiting for a response from Adobe. Very frustrating not to get a reply, let alone a solution to the problem.
Aug 29, 2010 Aug 29, 2010
I have had a ticket open for a while -- not seeing a lot of progress though.
I upgraded my laptop to CS5/LR3. It runs Vista. I am seeing the same issue on that machine as well. The switchboard process does not get started unless I first start Bridge. After that everthing works as it should. Two different computers, two different operating systems, two different user accounts and same problem.
My workaround is to first start Bridge (it has an option to be started automatically at logon to run in the background).
Mike - good to know there's a workaround, I'll give that a try! I still have the problem, and it take 4 tries every time I launch bridge.
Adobe support told me to do the following (see below the dashed line) I haven't tried solution 2 and the reinstall yet, as that's a bit more time-intensive and I haven't had the space in life to do that now. The solution 1 thing didn't work for me.
maybe this will help either of you? Please do let me know if it does!
Cheers.
I would like to inform you that i have found some troubleshooting steps
that can help you resolving the issue :
Reset Bridge preferences and default workspace, and purge the entire
thumbnail cache.
thumbnail cache to eliminate problems with unexpected behavior when
launching Bridge CS5.
Note: When you use this solution, Bridge will create new preferences and
a new default workspace, and you will lose custom settings associated
with your current preferences and workspace. The thumbnail cache will
re-created automatically when you start Bridge.
To reset Bridge preferences and default workspace and purge the
thumbnail cache:
1. Quit Bridge.
2. Hold down the Ctrl key while starting Adobe Bridge CS5.
3. Choose one or more of the following options from the Reset
Settings dialog box:
* Reset Preferences to reset Bridge preferences.
* Reset to Default Workspace to reset Bridge to the default
workspace.
* Purge Entire Thumbnail Cache to purge entire thumbnail
cache.
Solution 2 : Run Bridge while no other applications are running.
Some applications or services may cause system errors or freezes when
running concurrently with Bridge. Before starting Bridge, disable other
applications, including startup items and services (items that start
automatically with Windows).
To disable startup items and non Microsoft services:
1. Quit all applications.
2. Choose Start, type msconfig in the Search text box, and press
Enter.
3. Write down all unselected items under the Startup and Services
tabs.
4. Click the General tab, and choose Selective Startup.
5. Click the Startup tab and select Disable All.
6. Select any startup items that are essential for testing the
problem (for example, Adobe CS4 Service Manager). If you are unsure
whether an item is essential, leave it deselected (disabled).
7. Click the Services tab, and check Hide All Microsoft Services.
8. Select Disable All, then turn back FLEXnet Licensing Service and
click OK. If you are unsure whether an item is essential, leave it
9. Click Apply, and restart Windows for the changes to take effect.
Note: Upon restart, you'll be notified that the System
Configuration utility has made changes to the way that Windows starts u
p. Click OK. When the System Configuration utility appears click Cancel.
10. Right-click icons in the Notification Area and close or disable
any startup items that are still active.
Then, try to re-create the problem:
* If the problem no longer occurs, one of the startup items is the
cause of the problem.
* If the problem recurs, startup items are not the cause of the
problem and you can re-enable them:
1. Choose Start, type msconfig in the Search text box, and
press Enter.
2. Click the General tab, and choose Normal Startup.
3. Deselect any items that you wrote down in Step 3 of the
previous section.
4. Click Apply, and restart Windows for the changes to take
effect.
Also if the issue still persists then you need to reinstall Adobe Bridge
again and then try to launch Adobe Bridge CS5.
If you are unable to install an individual product that contains Bridge
(for example, Adobe Photoshop CS5) from your CD/DVD drive, then install
the individual product that contains Bridge from the desktop.
1. Copy the product installation disc that you have to the desktop.
2. Open the product folder that contains Bridge from the desktop.
3. Double-click the Setup.exe file, and then follow the on-screen
instructions.
This should resolve your issue. If it does, please let us know, however
in case it does not; please revert with any new information that you
might want to add which will help us in resolving your issue.
You can also try referring to our knowledge base and User to User
forums by clicking on the following links:
Knowledgebase: http://www.adobe.com/cfusion/search/index.cfm
U2U Forums: www.forums.adobe.com
Guest
Sep 10, 2010 Sep 10, 2010
Nico, I tried those steps, to no avail. I also tried Mike's work-around. But it did not work for me. I still get the SwitchBoard Server error message popping up whenver Bridge opens. It finally stops popping up after I delete it about 6 or 7 times and then Bridge works fine.
MiniBridge does not work though.The frustrating thing is that MB worked the first time I opened Photoshop CS5. I use Abobe products for at least 8-hours a day. I just wish I could more of their functionality.
