I would like to add other Eclipse Plug-ins to my version of (Eclipse) Flash Builder 4 on MacOSX, such as the free PDT (php developer tools) from the Eclipse Foundation. I have had no trouble downloading the standalone version of Galileo. I would however prefer to use it as a plug-in. I have asked Eclipse for help on this, but is so far unresolved. If there was a repository url that Flash Builder would accept without a JRE error or similar, that would be a great help. Thank You!
http://www.eclipse.org/projects/project_summary.php?projectid=tools.pdt
Please see this excellent video which helped me:
http://miti.pricope.com/2009/07/09/debug-flex-and-php-using-flash-builder-4-and-pdt/
and this:
http://www.riaspace.net/2009/12/configuring-eclipse-pdt-and-flash-builder-4-plug-in-for-phpflex-development/
Thanks for your reply. Gave it a try, but it is throwing this error:
Cannot complete the install because one or more required items could not be found.
Software being installed: PDT Runtime Feature 2.0.0.v20090315-1850 (org.eclipse.php.feature.group 2.0.0.v20090315-1850)
Missing requirement: PDT Runtime Feature 2.0.0.v20090315-1850 (org.eclipse.php.feature.group 2.0.0.v20090315-1850) requires 'org.eclipse.dltk.core.feature.group [1.0.0,2.0.0)' but it could not be found
The PDT runtime feature looks like it is part of the package I was downloading. Impasse...
try find
by itself
Don't install it as a plugin, use pdt standalone and just keep your php files seperate from your flex project. makes things more clear.
my pain is here:
http://forums.adobe.com/message/2867359#2867359
Well, seems like I got closer. But still mystified. Error:
conflicting dependency.
Software currently installed: Adobe Flash Builder 4.0.0 (com.adobe.flexbuilder.standalone.product 4.0.0)
Only one of the following can be installed at once:
International Components for Unicode for Java (ICU4J) 3.8.1.v20080530 (com.ibm.icu 3.8.1.v20080530)
International Components for Unicode for Java (ICU4J) 4.0.1.v20090822 (com.ibm.icu 4.0.1.v20090822)
etc
Go to
http://mayankkumar.com/blog/
There is a post from 13th Jun. 2009 on how to set up PDT and Flash builder 4. Try the workflow there and tell me if you still have those problems.
Nishad
I know it is an old thread, but here is how I installed PDT for Flash Builder
Since current Flash Builder is basically built on Eclipse Galileo, you just have to add the update site for Galileo:
http://download.eclipse.org/releases/galileo/
Once you add that, search for PDT, select it and you are ready to install PDT and all its dependencies.
cheers,
paCkeT
thanks, but in the end I just decided to run 2 seperate eclipse installs for each language, just is more stable. I may install a 3rd just for java dev
