10 Replies Latest reply on Aug 24, 2010 5:32 AM by betheflexcoder
    Flex. How to get textinput text values in dynamic..?
    Ling's Level 1
      Hi all.,
              I have using dynamic form to get  the textinput text values.
      <fx:Script>
              <![CDATA[
      public function init():void
                frmItem1 = new FormItem();
                  frmItem1.direction = "horizontal";
                  frmItem1.label = "Customer Name";
                  txtinput1 = new TextInput();
                  txtinput1.id="txt_custname";
                  txtinput1.width=170;
                  frmItem1.addElement(txtinput1);
                  userInfoForm.addElement(frmItem1);
        public function search_click():void
           user.text="custname"+.text;
          </fx:Script>
          <fx:form id="userInfoForm"/>
      <fx:Label id="user"/>
          <s:Button id="btn_search" label="Search" click="search_click();"/>
      error displayed.  how to get textinput id and text
      any one help this problem...
      Ling's
        • 1. Re: Flex. How to get textinput text values in dynamic..?
          Prestine
          use,
          str = txtinput1.text
          which will return the text contains in the TextInput.
          • 2. Re: Flex. How to get textinput text values in dynamic..?
            Ling's Level 1
            Thank u....
            but i want to add 2 r more textinput using loop  through arraycollection
            txtinput1.id="customer_id"
            txtinput1.id="customer_name"
            txtinput1.id="customer_address"
            txtinput1.id="customer_state"
            to get
            str1=customer_id.text;
            str1=customer_name.text
            str1=customer_address.text;
            str1=customer_state.text
            ist poosible to get the id in dynamic..?
            regards.,
            Ling's
            • 3. Re: Flex. How to get textinput text values in dynamic..?
              betheflexcoder Level 2
              How about using your custom textinput, so that you can create dynamic ids for each of its instances.
              • 4. Re: Flex. How to get textinput text values in dynamic..?
                Vackar Level 2
                You could try userInfoForm.getChildren();
                This returns the list of FormItem Objects.
                Then for each one call getChildren().getItem(0) to get the text box.
                Note: I haven't compiled this - syntax may not be exact.
                Vackar
                • 5. Re: Flex. How to get textinput text values in dynamic..?
                  Ling's Level 1
                  any sample coding to solve this problem.....
                  regards.,
                  • 6. Re: Flex. How to get textinput text values in dynamic..?
                    Balakrishnan V
                    I am not very sure what you are trying to achieve; In any case, with my understanding here are a couple of my suggestions
                    You can have the TextInput components as an ArrayCollection.
                    var textInputArrayCollection:ArrayCollection=new ArrayCollection()
                    var textInput1:TextInput=new TextInput();
                    //either declare your component in mxml and set textInput1=mxmlTextInputComponent
                    //and repeatedly do texInputArrayCollection.addItem(textInput1)
                    textInput1.id="abc"
                    //set other properties - here no mxml declaration
                    textInputArrayCollection.addItem(textInput1)
                    You can use TextInput(textInputArrayCollection.getItemAt(i)) to access any properties.
                    OR, you can map the textinputs through an object
                    var obj:Object=new Object();
                    obj["textInput1"]=textInput1
                    obj["textInput2"]=textInput2 .....
                    Hope this helps, If you could e3laborate what u want to do, I could help better !
                    balakrishnan v
                    • 7. Re: Flex. How to get textinput text values in dynamic..?
                      Ling's Level 1
                      thank u...
                      Form is created dynamic., with  4 formitem and   textinput
                      <fx:Script>
                              <![CDATA[
                      //dataist  arraycollectiion data .
                                     [Bindable]
                                  public var dataist:ArrayCollection = new ArrayCollection( [
                                      { spkName:customer Name', dataName:'customer_name'},
                                      { spkName:customer address', dataName:'customer_add'},
                                     { spkName:customer state', dataName:'customer_state'},
                                     { spkName:customer city', dataName:'customer_city'}
                      public var frmitem:FormItem;
                      public var txtInput:TextInput;
                         // loop is executed 4 times
                        for(var i:int = 0; i < dataist.length(); i++)
                          var formlabel:String= lst[i].spkName;
                         var textvalues:String= lst[i].dataName;
                              frmItem = new FormItem();
                              frmItem.direction = "horizontal";
                              frmItem.label = formlabel;
                              txtInput = new TextInput();
                              txtInput.id= textvalues;
                              frmItem.addChild(txtInput);
                      userInfoForm.addChild(frmItem);
                      public function buttonclick():void
                      // Error displayed
                      var customername:String=txtInput.text;   OR    var customername:String="customer_name"+.text;
                      var customeradd:String=txtInput.text;
                      var customerstate:String=txtInput.text;
                      var customercity:String=txtInput.text;
                      // How to get all textinput text ...
                          </fx:Script>
                          <mx:VBox >
                              <mx:HBox>
                                   <mx:Form  id="userInfoForm" >
                                   </mx:Form>
                               </mx:HBox>
                          <mx:Button id="test"  label="Click" click="buttonclick()" />
                            </mx:VBox>
                      regards
                      Ling's
                      • 8. Re: Flex. How to get textinput text values in dynamic..?
                        Balakrishnan V Level 3
                        <fx:Script>
                                <![CDATA[
                                       [Bindable] public var dataist:ArrayCollection = new ArrayCollection( [
                                        { spkName:customer city', dataName:'customer_city'}])
                        // Error displayed
                        var customername:String=userInfoform.getChildAt(0).text;
                        OR var customername:String=TextInput(userInfoForm.getChildAt(0)).text
                        Hope this helps,
                        Balakrishnan V
                        • 9. Re: Flex. How to get textinput text values in dynamic..?
                          Ling's Level 1
                          Error display
                          Type Coercion failed: cannot convert mx.containers::FormItem@3a7040a1 to mx.controls.TextInput.
                          userInfoForm form is mx.container
                          TextInput is mx.control.
                          how to conver this...
                          • 10. Re: Flex. How to get textinput text values in dynamic..?
                            You have get the child of the formitem and then type cast it ti textinput.
                            May be like,
                            var customerFormItem:FormItem =FormItem(userInfoForm.getChildAt(0));
                            var customerName:String = TextInput(customerFormItem.getCHildAt(0)).text;
