I want to put two click boxes on one slide.
User can either click one box to skip to end of the project or click the other box to move to next slide and continue slide by slide to the end.
I can only get the continue click box to work, nothing happens when I try the "end" option.
I must be missing the obvious....can anyone point it out to me please?
Noel
Staffordshire
England
Hi Noel
Do the Click Boxes overlap where they share screen real estate? If so, perhaps that's why the one linking to the end of the project is failing.
Another issue could be if you have quizzing enabled. Sometimes folks enable quizzing and configure it so that ALL the elements of the quiz must be answered before it is deemed complete. In this case Captivate will disallow "skipping over" the unanswered questions or quiz elements because they must be answered.
Cheers... Rick
Helpful and Handy Links Begin learning Captivate 5 moments from now! $29.95 Captivate Wish Form/Bug Reporting Form |
Are you using Cp4? Two things spring to mind:
I am using Captivate 4.
Reporting is off...as there is no reporting.
I have removed the 2nd "next" click box for time being, in case that was the problem so only have the one click box now which I want to jump from slide 2 to slide 24 of 24.
Still wont do it. It will allow me to jump from slide 2 (location of the click box) to slide 6...but not to 7 or beyond.
Slide 7 which seems to be the block is a simple screen recording with a single callout on it, nothing else.
Hi Noel
Slide 7 may not be the issue.
What does Slide 6 have on it? Can you post a screen capture of the Timeline for that slide?
Cheers... Rick
Also, does the project have any Advanced Actions defined? I ask because I've attempted to help others by constructing scenarios where specific slides shouldn't be reached until certain criteria were met.
Cheers... Rick
Hi Rick...I have never used Advanced Actions, so unless I have enabled this by mistake, then there should be non
e...where can i check?
Meanwhile here is slide 6...et al
I have found out the cause of the problem...Me!
I had placed the click button on slide 2 and instead of taking me to the end slide (23), it was always taking me to slide 7.
After many attempts to fix this...none of which worked, I went home frustrated and overnight the solution came to me.
When I was testing the click button, which should have taken me to slide 23, I was using the F10 option...which only previews the next 5 slides, hence only getting as far as slide 7 (2+5)...
I have now testing it in full project...and it works just fine...
Thought I should send this update, in case anyone else falls into same trap.
Noel
