TCS 2 (RoboHelp 8, WebHelp, 700+ topic knowledge base, no CSH
Hi all,
I'm working with a client who has quite a "wish list" for their WebHelp system (which may be moving to WebHelp Pro if they jump through corporate hoops to get their RoboHelp Server in place). I'm looking for input on which of these customizations are possible, and if so, any pointers you can give to lead me in the right direction. The good news is that I have a developer who can create whatever scripts, etc. I need.... the bad news is he hasn't worked within the parameters of RoboHelp/WebHelp before. We also need to provide the client with time estimates for each of these customizations, and the solutions can't require ongoing work/maintenance once they're implemented.
Thanks in advance!
Katie Carver
Senior Technical Communicator
Docs-to-You, LLC
Hi Katie. There is a lot of food for thought here so bare with me as I try and (hopefully) add some answers to your questions.
Automatically expand text in dropdowns
I see a slight issue here as what would happen if a search returns two topics. Or are you just talking about when a topic is chosen to be displayed from the search results? Peter grainge has outlined a method that worked for him here.
Recent update button
Typically this is done by the writer via a button linked to a dropdown or someother such method. It could include a simple summary statement (e.g. Updated to include the ability to add blue widgets) rather than the specific textual change.
Welcome page comment box
This sounds like the AirHelp (rather than WebHelp) output maybe the way to go here. This would allow comments across all the content, not just one page. If you only want it on one page this should be achievable with your developers help. I guess you'd need some script to pass the comments to some sort of repository (e.g. Access DB).
Search context
If your client gets the go ahead for the RoboHelp Server application it will provide context to the search results and ranks them also.
Hope this is of some use. No doubt others will chip in with ideas and comments.
The RoboColum(n) | @robocolumn | Colum McAndrew |
Thanks for the helpful information, Column. Please see my responses...
- Katie
Correct; when a topic is chosen to be displayed from the search results, they want the dropdowns to auto-expand if the dropdowns contain the search term. The methods on Peter's site sound great for creating a link that auto-expands a dropdown...but that won't work for Search will it? Here's the scoop from the developer I'm working with:
For some reason, they have chosen to highlight the text by enclosing it in a font tag (of all
things) and applying an RGB color to it with a style declaration. Ugh.
For our purposes, this is about the worst way they could have done it. However, it is possible. And if THAT is possible, then it's also possible to find the highlighted text within a hidden section and unhide it.
Typically this is done by the writer via a button linked to a dropdown or someother such method. It could include a simple summary statement (e.g. Updated to include the ability to add blue widgets) rather than the specific textual change. We are steering them in that direction.
This sounds like the AirHelp (rather than WebHelp) output maybe the way to go here. This would allow comments across all the content, not just one page. If you only want it on one page this should be achievable with your developers help. I guess you'd need some script to pass the comments to some sort of repository (e.g. Access DB). That's exactly what I told them (AIR Help), but they are interested in the usage tracking/reports that the RoboHelp Server - WebHelp Pro solution provides. It sounds like we'll need to work with their IT deparment to implement a solution on the web server that we will hook up to a general comments form in the WebHelp (not going to attempt to make it topic-specific).
Search context
If your client gets the go ahead for the RoboHelp Server application it will provide context to the search results and ranks them also. Does RoboHelp Server let you control what is displayed as the context? They have information at the top of all of their topics that is not helpful if it is what appears as the context. They'd like it to pull from a bit farther down in the topic.
Pinching Colum's headings...
That method was not intended to work from search results. Given that the method requires the call to the dropdown to contain the dropdown ID, I cannot see how you would get that into the search results.
You can see an example of what Colum has suggested on my site. Most topics have a Revisions button at the end. Click a few and see how it works. I have used a javascript method as the site is maintained using Dreamweaver. RoboHelp comes with Dropdown functionality built in.
Colum is right that locally installed AIR help would allow users to make comments but whether or not that route is viable will depend on your developers' and customers' views on installing the help on each user's desktop and their access to the internet. There is information about AIR help on my site and it covers what you would need to set up.
I suspect you might find Colum's other suggestions of getting your developers involved in setting something up from the webhelp would be less of a logistical nightmare.
Search context
Ordinary webhelp gives you context but you don't get to force it to be what you want. I wasn't aware it was any different with Pro but Colum will be able to advise on that. If not, there is an article about ZoomSearch on my site and you can get that to include text that you define for each topic. May still not be quite what you want but it would be closer.
Katie
My reply was written before you last post appeared so read it that way.
Thanks, Peter. Your site is very helpful; I refer to it frequently, but never came across the ZoomSearch information. I'm looking at it now and am quite intrigued.
- Katie
My apologies for the typo on Colum's name in my earlier post. (I've been discussing table columns in an email thread all morning -- oops! )
- Katie
