Hello,
my webserver data are as follows:
ColdFusion 5 (is there a particular hotfix you are looking for)?
Windows Server 2003
IIS 6.1.
I would like to do a redirect.
Specification:
For the URL field:
1. If a user enters XXXX.com the user will be pointed to:
http://XXXX.com/MainPath/Main.html
2. If a user enters www.XXXX.com the user will be pointed to:
http://www.XXXX.com/MainPath/Main.html
3. If a user enters XXXX.com/name1 the user will be pointed to http://XXXX.com/Path1
4. If a user enters XXX.com/name2 the user will be pointed to http://XXXX.com/Path2
5. If a user enters XXX.com/name3 the user will be pointed to http://XXXX.com/Path3
I am using this code:
<!--- Default locations --->
<CFIF server_name IS "www.XXXX.com" OR server_name IS "XXXX.com">
<CFLOCATION url="MainPath/Main.html">
<!--- For XXXX.com/name1 --->
<CFELSEIF CompareNoCase(cgi.server_name, "XXXX.com") EQ 0 AND CompareNoCase(ListGetAt(cgi.path_info, 1, "/"),"name1") EQ 0>
<CFLOCATION url=" http://XXXX.com/Path1">
<!--- For XXXX.com/korrosion point to Io00Korro01.cfm --->
<CFELSEIF CompareNoCase(cgi.server_name, "XXXX.com") EQ 0 AND CompareNoCase(ListGetAt(cgi.path_info, 1, "/")," name2") EQ 0>
<CFLOCATION url=" http://XXXX.com/Path2">
<!--- For XXXX.com/cell point to CellCycle01.cfm --->
<CFELSEIF CompareNoCase(cgi.server_name, "XXXX.com") EQ 0 AND CompareNoCase(ListGetAt(cgi.path_info, 1, "/")," name3") EQ 0>
<CFLOCATION url=" http://XXXX.com/Path3">
</CFIF>
Specification 1 and 2 above work well with <!--- Default locations --->
But the rest of the code won't do the desired redirects of specification 3 to 5.
Help would be appreciated.
Phnoefniex
Comment out the cflocation tags so you can look at your data. Then do this sort of thing.
<cfif something>
yes
<cfelse>
no
<cfdump var="#the_variables_you_were_looking_at#">
closing tags.
adjusted for your own code of course.
At first glance, it looks like you overengineered the whole thing.
Hello,
Not sure how to get <cfdump> to work. So I did a test.
I have default.cfm under the root directory.
It only contains this line:
<cfdump var="#URL#">
If I enter XXXX.com into the browser URL it will just display a blank page. How can I get the dump to display in the browser?
Thanks, Phnoefniex
Are you sure that default.cfm is automatically servers by your web server. That file is not a common automatic file. ColdFusion usually only configures index.cfm to be automatically serverd if no specific file is requested.
Have you tried XXXX.com/default.cfm do you see the dump display then? Which, of course, is going to be empty becuase you have no url parameters. xxxx.com/default.cfm?test=foobar will show some data in the dump.
