I'm having problems setting up coldfusion 9, and I've narrowed it down to the web server configuration tool.
First, the server is running a brand new install of Windows 2008 R2 64bit. It's running IIS 7.5, and I've enabled ISAPI filters+extension, and IIS6 metabase compatibility.
The server is one of 1&1's new cloud offerings. I don't think this should be the problem, unless it's a way they've configured it.
I've already successfully installed CF9 on the same OS on a dedicated server with a different host.
Anyway, running the CF9 64 bit installer seems to work ok, but it doesn't configure up IIS. I've tried installing/uninstalling/re-imaging the server several times with no success.
To confirm my suspicions that CF was installing ok, I tried it using the built in web-server on port 8500, and that works fine.
I've tried running the web server configuration gui tool, but I get the following message:
Could not connect to any JRun/ColdFusion servers on host localhost.
Possible causes:
o Server not running
-Start Macromedia JRun4 or ColdFusion MX server
o Server running
-JNDI listen port in jndi.properties blocked by TCP/IP filtering or firewall on server
-host restriction in security.properties blocking communication with server
Googling this found several blog posts for earlier version of CF. Most suggest running the 'netstat -an' command, which gives:
Active Connections
Proto Local Address Foreign Address State
TCP 0.0.0.0:80 0.0.0.0:0 LISTENING
TCP 0.0.0.0:135 0.0.0.0:0 LISTENING
TCP 0.0.0.0:445 0.0.0.0:0 LISTENING
TCP 0.0.0.0:1688 0.0.0.0:0 LISTENING
TCP 0.0.0.0:2522 0.0.0.0:0 LISTENING
TCP 0.0.0.0:2932 0.0.0.0:0 LISTENING
TCP 0.0.0.0:3389 0.0.0.0:0 LISTENING
TCP 0.0.0.0:6085 0.0.0.0:0 LISTENING
TCP 0.0.0.0:6086 0.0.0.0:0 LISTENING
TCP 0.0.0.0:7997 0.0.0.0:0 LISTENING
TCP 0.0.0.0:8500 0.0.0.0:0 LISTENING
TCP 0.0.0.0:8983 0.0.0.0:0 LISTENING
TCP 0.0.0.0:9923 0.0.0.0:0 LISTENING
TCP 0.0.0.0:9953 0.0.0.0:0 LISTENING
TCP 0.0.0.0:9963 0.0.0.0:0 LISTENING
TCP 0.0.0.0:19999 0.0.0.0:0 LISTENING
TCP 0.0.0.0:20000 0.0.0.0:0 LISTENING
TCP 0.0.0.0:47001 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49152 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49153 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49154 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49155 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49156 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49201 0.0.0.0:0 LISTENING
TCP 127.0.0.1:8079 0.0.0.0:0 LISTENING
TCP 127.0.0.1:9953 127.0.0.1:49186 ESTABLISHED
TCP 127.0.0.1:49186 127.0.0.1:9953 ESTABLISHED
TCP 127.0.0.1:49538 127.0.0.1:9923 TIME_WAIT
TCP 127.0.0.1:49539 127.0.0.1:9963 TIME_WAIT
TCP 127.0.0.1:49540 127.0.0.1:9923 TIME_WAIT
TCP 127.0.0.1:49541 127.0.0.1:9963 TIME_WAIT
TCP 127.0.0.1:49542 127.0.0.1:9923 TIME_WAIT
TCP 127.0.0.1:49543 127.0.0.1:9963 TIME_WAIT
TCP 127.0.0.1:49544 127.0.0.1:9923 TIME_WAIT
TCP 127.0.0.1:49545 127.0.0.1:9963 TIME_WAIT
TCP [::]:80 [::]:0 LISTENING
TCP [::]:135 [::]:0 LISTENING
TCP [::]:445 [::]:0 LISTENING
TCP [::]:1688 [::]:0 LISTENING
TCP [::]:2522 [::]:0 LISTENING
TCP [::]:2932 [::]:0 LISTENING
TCP [::]:3389 [::]:0 LISTENING
TCP [::]:6085 [::]:0 LISTENING
TCP [::]:7997 [::]:0 LISTENING
TCP [::]:8500 [::]:0 LISTENING
TCP [::]:8983 [::]:0 LISTENING
TCP [::]:47001 [::]:0 LISTENING
TCP [::]:49152 [::]:0 LISTENING
TCP [::]:49153 [::]:0 LISTENING
TCP [::]:49154 [::]:0 LISTENING
TCP [::]:49155 [::]:0 LISTENING
TCP [::]:49156 [::]:0 LISTENING
TCP [::]:49201 [::]:0 LISTENING
UDP 0.0.0.0:500 *:*
UDP 0.0.0.0:4500 *:*
UDP 0.0.0.0:5355 *:*
UDP 0.0.0.0:62255 *:*
UDP 0.0.0.0:62257 *:*
UDP 0.0.0.0:62259 *:*
UDP 0.0.0.0:62261 *:*
UDP 127.0.0.1:62253 *:*
UDP 127.0.0.1:62254 *:*
UDP 127.0.0.1:62256 *:*
UDP 127.0.0.1:62258 *:*
UDP 127.0.0.1:62260 *:*
UDP 127.0.0.1:62262 *:*
UDP [::]:500 *:*
UDP [::]:4500 *:*
UDP [::]:5355 *:*
I've removed a few lines that mentioned the external IP of the server, but I don't think they're important.
The main thing, is that it seems to be listening on port 2932 which is configured in jndi.properties
At this point I'm stuck.
I did find some blog posts that suggested adding some arguments to narrow the ports scanned when you run the configuration tool. I tried them without success - as they were quite old, is it possible they have changed with the latest config tool?
The other thing I've contemplated is connecting IIS manually. However, I can't find any instructions for doing this with CF9.
Does anyone have any suggestions?
Thanks in advance,
Gareth
At this point I'm stuck. I did find some blog posts that suggested adding some arguments to narrow the ports scanned when you run the configuration tool. I tried them without success - as they were quite old, is it possible they have changed with the latest config tool?
Do you mean you did something like this on the command line? If so, what was the result?
C:\ColdFusion9\runtime\jre\bin\java.exe -DWSConfig.PortScanStartPort=2932 -DWSConfig.PortScanCount=1 -jar C:\ColdFusion9\runtime\lib\wsconfig.jar
Hi BKBK,
When I run that command, it launches the gui. I click the 'add' button, and it eventually gives me the same message as before:
Possible causes:
o Server running
Not knowing how the configuration tool is working, means I don't know what to check for next. The netstat report indicates that it should be able to see coldfusion on port 2932. Adding those command arguments means it shouldn't time out looking for coldfusion.
Is there anything else I could try?
Gareth
In case anyone else gets stuck on this, the problem turned out to be packet filter software that 1&1 installed by default.
It's meant to act a bit like a firewall, but is over-zealous. Apart from the standard http/ftp etc ports, everything else is locked down, to such an extent that coldfusion can't even see itself on the same machine.
The solution is to just turn it off, and use their network firewall instead.
We also had problems with 1&1's installation of MS SQL 2008. We couldn't set up DSNs in coldfusion, and eventually had to re-install ms sql to get things working.
It's taken ages to set up, but the server's running well now. The ability to change hardware specs in minutes is great, and something we've used already.
What is the name of the package filter software on 1and1's server? I have the same problem.
There should be an icon on your desktop called 'IP Filter', although the exact name may depend on the server package you have with them.
If you search through 1&1's help section, they should have instructions for it.
I just turned it off completely, and used their network firewall instead.I tried configuring the IP filter, but it didn't seem to work the way I wanted.
You are king thx man been having this issue for days now - also 1&1 Cloud Server - finally it works
