Hi to evryone..
I am the very new person for Robohelp,Still i hav'nt this software. but i looking to use this.
i hav some basic question it.it is very simple for u but important for me..
plz help me...
1. what is the file extension of robohelp file after creating this..is it html file or not??
2.can we write down directly in robohelp or we hav to must use editor like ms word,notepad..etc??
3. how to integrate this robohelp file in our project. our project is in java or jsf??
4. what is best edition or version for me use.??
please please answer such question. i very confusing about all this question....
thanks in advance. it w'l takes ur valuable time but i hepls me lot..
plz
Hi opsmca and welcome to the RH forums. So many questions so let's get to them
Finally I'd really recommend that you at the very least download a RoboHelp trial. This is a fully working version that you can use for 28 days. It should give you a good idea of further questions to ask! There are also a number of useful RoboHelp resources you can tap into:
The RoboColum(n) | @robocolumn | Colum McAndrew |
You can try RoboHelp within the Technical Communication Suite without downloading it.
http://www.runaware.com/clients/adobe/techsuite/
Thanks to you for giving me your valuable time n knowledge.
actually my system ram is 1GB or windows xp 2000.
1. plz tell the exact hardware requirement for robohelp?
2. what is
Your system requirements are OK. Check out what is required here.
The Technical Communications Suite is a collection of Adobe applications (of which RoboHelp is one) that provides you with many benefits. However it is not for everyone. It sounds like your work will be limited solely to the production of help documentation with no software simulations. If so, you probably won't need it.
RoboHelp must be installed and run locally so a server is not required. Output from RoboHelp can be placed on a server if you require. There is even a product called RoboHelp Server that can be used to host RoboHelp output and produce statistical reports. This is a separate licence from RoboHelp.
Again
heartly thanks to u for giving such valuable information so quickly.
let me know that if i doesn't require full suit then may i can download only robohelp.
can i create search button in help file.. is there any direct tool for that.
within two or more days i hav to start work robohelp so if further any stuff
comes then i concern with you. n i hope i get same responce...
thanks
If I was you I'd download the trial version of RoboHelp and start playing with it. You will have questions but you can ask them on these forums. A Search button can be easily included as part of your output.
