I was wondering if there is a way to permanently change the default structure of the output in the RH application. I realize that you can take your SSL and point to a directory, but if you create a new version of that SSL it automatically points to the default structure and it will create that structure inside the project even though you don't use it. We have to be careful of the structure that's built for SVN and other command line junk we do.
I don't think that is possible. There are some things where you can go to Program Files and find the file within the RoboHelp files that contains hard coded information so you can force Oranges to always be Lemons. However, the default you want to change is not hard coded, it is calculated and displays the !SSL! folder for the project you have just created. It is inserted on the fly. For that reason I think you would need to amend the code that performs that calculation. Good luck on that one!
