this is the usual way to create a new project in Flex 3, and works fine, but now in flash buider 4:
the web root and root url are ok, what is the source of the warning message?
thanks
Is it fair to assume that you're configuring CF info on purpose, because if you don't use CF, I think you can skip that screen safely.
If you're using CF intentionally:
- do you have a CF server in the default location shown?
- have you tried using the built-in server?
-Chris
Hi Chris, thanks for your answer,
Yes, I'm using CF intentionally, actually, I'm using CF with flex 3, but I just got FB 4 and I'm trying to configure it to migrate my apps, it looks easy but I could not do it.
Yes, CF server is in the default location
Yes, I already tried with the built-in server and it works ok
I do not really know where the problem is, and I have not seen that warning before.
Please post me back with any other helpful comment,
Ramon
CFIDE is the folder where you can find all the pre-defined components that will be used to introspect your CFC files. Flash Builder expects that CFIDE be under the webroot. For example if the web root is c:\wamp\www, FB expectes CFIDE to be under www folder. The default installation of ColdFusion will be like this.
-Sunil
Yes, I know it, but using IIS the CFIDE folder is located in c:/inetpub/wwwroot/CFIDE , in production server, CFIDE has to be a virtual directory under each web site, but in local server you do not need it.
Ramon
