1. Re: Printer vs Screen
Noel Carboni Aug 26, 2010 1:04 PM (in response to GESYMSB)If you create a perfect circle, by choosing the Ellipse drawing tool and holding the shift key down while dragging to increase the size, does the diameter of the circular shape measure the same horizontally and vertically on the screen or printer? I'm trying to find out which is giving you the distortion.
-Noel
2. Re: Printer vs Screen
D Fosse-QDEaQ1 Aug 26, 2010 10:03 AM (in response to GESYMSB)Does your monitor run at native resolution? If it doesn't, the aspect ratio might be a little off.
How do you make the circle? Try to hold the shift key with the elliptical marquee tool. This will constrain it to a perfect circle, so you can check on screen.
Edit: cross-post
3. Re: Printer vs Screen
GESYMSB Aug 27, 2010 7:20 AM (in response to Noel Carboni)The circle is perfect on the screen.
However when you print, on the paper is like a little bit streched ( enlongated )
-Noel
4. Re: Printer vs Screen
GESYMSB Aug 27, 2010 7:20 AM (in response to Noel Carboni)The circle is perfect on photoshop ( screen )
The printout is always like a little bit streched ( enlongaded )
-Noel
5. Re: Printer vs Screen
Hobotor Aug 27, 2010 10:01 AM (in response to GESYMSB)I think you're not running on native resolution and have distorted the images by using the monitor setting to "fit" into place.
To be more clear:
You have set your monitor to a wrong resolution, causing your image to appear elongated. Then you used the monitor controls to compensate for the elongation. Result: image looks fine on screen, but actually "is" distorted.
Just a guess tho
7. Re: Printer vs Screen
To be more clear:
That was my thought too. I have seen it on several customers' computers. Sometimes they get a new monitor and wonder why it's like that.
8. Re: Printer vs Screen
GESYMSB Aug 27, 2010 1:12 PM (in response to GESYMSB)Thanks folks, I think the problem may have to do with the monitor
native resolution like you folks indicated.
The "View" is exactly as that picture of Noel menu, "Square Pixels "
Here is a picture of the problem.
Imagine a perfect circle on Photoshop and what comes in the paper...
9. Re: Printer vs Screen
Noel Carboni Aug 27, 2010 1:49 PM (in response to GESYMSB)Correct me if I'm wrong, but if it is a perfect circle as created in Photoshop (you DID hold down the shift key, right?) and as measured on the monitor, then the monitor can't really be the issue, right? It has to be the printer.
Does a print of a 4 x 6 photo come out to exactly 4 x 6 inches, or is it stretched?
If it is stretched there's something wrong with the printer interface or the printer itself.
-Noel
10. Re: Printer vs Screen
GESYMSB Aug 28, 2010 6:04 AM (in response to Noel Carboni)Good question, I always get a message from Photoshop telling me that
the paper is not the right size or something like that.
But the strech to fit switch is off, should print what you see on
photoshop, well the results you saw it on that picture.
Correct me if I'm wrong, but if it is a perfect circle as created in Photoshop and as measured on the monitor, then the monitor can't really be the issue, right? It has to be the printer.
-Noel
11. Re: Printer vs Screen
GESYMSB Aug 28, 2010 6:05 AM (in response to Hobotor)The image / pictures are PERFECT on the monitor.
To be more clear:
Just a guess tho
