1. Re: Deinterlacing a Video
Ann Bens Aug 26, 2010 10:00 AM (in response to GESYMSB)Or export with no fields.
2. Re: Deinterlacing a Video
GESYMSB Aug 27, 2010 5:38 AM (in response to Ann Bens)What I am trying is, to figure out how to eliminate the artifact created on
vertical lines, for what I had read, this is because the interlace.
Date: Thu, 26 Aug 2010 11:00:21 -0600
Subject: Deinterlacing a Video
3. Re: Deinterlacing a Video
Ann Bens Aug 27, 2010 8:48 AM (in response to GESYMSB)Well that depends.
If you are making a DVD or BD you can leave it interlaced.
All other like web or Youtube you need to deinterlace.
Which export format are you planning on using?
5. Re: Deinterlacing a Video
Harm Millaard Aug 27, 2010 1:38 PM (in response to GESYMSB)1. It is in general a very bad idea to deinterlace interlaced material, because you throw away 50% of the vertical resolution, leaving you with less than VHS resolution.
2. It is impossible to judge quality on the preview monitor. Use a properly calibrated professional monitor for that purpose.
6. Re: Deinterlacing a Video
able123 Aug 27, 2010 2:52 PM (in response to Harm Millaard)--------------- Harm wrote -----------
THIS IS ABSOLUTELY TRUE !!!!!
I had the same problem a while back, playing an mpeg 2 dvd on my computer in various media players and the video looked HORRIBLE ! Finally ( probably Harm ...but someone here at least ) Told me about this problem and I thought to myself, "HA, THAT CANT BE SUCH A HUGE DIFFERENCE ( doubting anything so bad could look OK once I burned the DVD ) ---
Putting my doubts aside I did burn the DVD , stuck it in the TV DVD player and WOW...it looked GREAT !...
True !
7. Re: Deinterlacing a Video
Bill Hunt Aug 27, 2010 4:31 PM (in response to GESYMSB)What are the specs. and the Field Order of your source files?
Good luck,
Hunt
8. Re: Deinterlacing a Video
GESYMSB Aug 28, 2010 5:54 AM (in response to Harm Millaard)But preview or not, that's what you may get on the final video.
Date: Fri, 27 Aug 2010 14:38:14 -0600
9. Re: Deinterlacing a Video
able123 Aug 28, 2010 6:24 AM (in response to GESYMSB)I was hoping you had done a test dvd burn interlaced , and played on TV DVD...
Will I never find out if it's OK ?
10. Re: Deinterlacing a Video
Ann Bens Aug 28, 2010 6:47 AM (in response to GESYMSB)It is better to use a original screendump then using one from this site:
And yes it does matter what you are make and what your source files are.
11. Re: Deinterlacing a Video
GESYMSB Aug 28, 2010 10:12 AM (in response to able123)I already told you I did.
Date: Sat, 28 Aug 2010 07:24:35 -0600
