Locked
Connect to Data/Service (PHP) problems should be fixed
Aug 28, 2010 Aug 28, 2010
1.insert ByteArray into or select from mysql blob with PHP ERROR
The default code is error, I couldn't insert ByteArray data into mysql till I add the mysqli_send_long_data() method.
  • $stmt = mysqli_prepare($this->connection, "INSERT INTO $this->tablename (info, info2) VALUES (?, ?)");
  • $this->throwExceptionOnError();
  • mysqli_stmt_bind_param($stmt, 'bs', $item->info, $item->info2);
  • mysqli_send_long_data($stmt, 0, $item->info);
  • mysqli_stmt_execute($stmt);
And add $stmt->store_result(); when you get blob data:
  • $stmt->store_result();
  • foreach($rows as $value){
         if($value->info){                    $value->info = new Zend_Amf_Value_ByteArray($value->info);               }           }            reference:http://blogs.sun.com/oswald/entry/php_s_mysqli_extension_storing
2.Test Operation is ok, but use in application couldn't work.   I have to change the PHP function name to make it shown in flash builder color "gray" , and then it works.
3.The auto created method like update... and delete... should be like below, return the affected num.
  • $affected = mysqli_stmt_affected_rows($stmt);
  • mysqli_stmt_free_result($stmt);
  • mysqli_close($this->connection);
  • return $affected;
700
Aug 29, 2010 Aug 29, 2010
Anybody agree with me?
Adobe Employee ,
Can you pls. file bug for this at http://bugs.adobe.com/flex
-Sunil
Aug 30, 2010 Aug 30, 2010
Sorry , I can't sing in bug system.
