1. Re: Duel Monitors
Todd_Kopriva Aug 27, 2010 9:42 PM (in response to Jarliei)Are you not able to just drag the application window to the second monitor?
2. Re: Duel Monitors
jeremy d. Aug 28, 2010 8:56 AM (in response to Todd_Kopriva)Yeah, you should be able to just drag the window over.
You should also futz around with the display card settings; you can get Premiere or any other app to always launch in a 2nd monitor.
3. Re: Duel Monitors
steveprc Aug 28, 2010 2:18 PM (in response to Jarliei)If you're working on a PC, simply open the program, drag the window on to the monitor of your choice, then restore and maximize the window, and finally close Premiere. This sets the standard window size when the software is opened, and the monitor on which it's opened. A dual monitor set-up views all the available screen space as a single display, so the position and size of the window when the software is launched, is treated in the same manner as it would be with a single monitor.
5. Re: Duel Monitors
Jarliei Aug 29, 2010 3:59 PM (in response to shooternz)it will do the job, but method is too "Agriculteral" ! :-)
6. Re: Duel Monitors
Jarliei Aug 29, 2010 4:01 PM (in response to steveprc)Much obliged, I've followed suit and it solved my problem.
7. Re: Duel Monitors
steveprc Aug 29, 2010 4:11 PM (in response to Jarliei)If you just swap the plugs, your mouse won't cross over in the center anymore. You'll have to go the long way around.
