Hi again Janise
Yes, as long as you can display what you need on the XP
desktop, you should be good to go.
Keep in mind that your best result will likely be obtained by
creating the voiceover as a separate process and not while you are
recording the initial movie.
Also, you may discover that the remote destop won't paint
quite fast enough so Captivate will record "blank screens" here and
there. Where you notice this happening, press the Print Screen key
to force additional screen captures. It's always easier to delete
unwanted slides than it is to re-create them when needed.
Cheers... Rick
