1. Re: Using CFINPUT dateField with onChange
DLAH Sep 29, 2006 7:44 AM (in response to DLAH)I think I'm almost there with:
<CFINPUT NAME="currdate"
ONCHANGE="getURL('index2.cfm?CurrDate=' + currdate.selectedDate, '_self')"
TYPE="datefield"
VALUE="#newCurrDate#" />
But it returns the value in the wrong format like:
index2.cfm?CurrDate=Thu%20Sep%2014%2000:00:00%20GMT-0700%202000
How do I format/simplify the "currdate.selectedDate"? -
2. Re: Using CFINPUT dateField with onChange
DLAH Oct 4, 2006 12:08 PM (in response to DLAH)Further to this issue, consider the following basic code that works with handling a selectedDate:
<!--- Set initial dates.--->
<cfparam name="Form.selectdate" default="#dateformat(now(), 'mm/dd/yyyy')#">
<!--- Display the current date value. --->
<cfif isDefined("Form.submitit")>
<cfoutput><b>You selected #Form.selectDate#</b><br><br></cfoutput>
<cfelse>
<cfoutput><b>Form date is #Form.selectDate#</b><br><br></cfoutput>
</cfif>
<b>Please select a date on the calendar and click Save.</b><br>
<br>
<cfform name="form1" format="Flash" skin="haloBlue" width="375" height="350" >
<cfinput type="dateField"
name="selectdate"
label="Initial date"
width="100"
value="#Form.selectdate#" >
<cfinput type="Submit" name="submitit" value="Save" width="100">
</cfform>
I would like to accomplish the same thing but use onChange instead of a submit. -
3. Using CFINPUT dateField with onChange
mcadle Oct 19, 2006 6:24 PM (in response to DLAH)Why don't you just use:
<cfinput type="date..." name="test" onchange="{_root.formfieldtochange.text=_root.test.text;}">
<cfinput type="text" name="formfieldtochange">
Whenever you update the datepicker, it will automatically change the value in the other field. -
4. Re: Using CFINPUT dateField with onChange
YogeshM Aug 29, 2010 6:38 AM (in response to mcadle)The onChange event doesn't work with cfinput type datefield using CFML in a plain HTML form.
In Flash form and flex, the onChange event works perfectly, i.e. whenever you choose a new date, the event fires.
In HTML form, when you choose a new date from the datefield, the event doesn't fire. You have to select the new date, then click into the textbox and hit the enter key. Then only it fires the onChange event. Very strange indeed!
Any ideas how to get this feature working or is it a bug in CF itself?
Thanks.
5. Re: Using CFINPUT dateField with onChange
Adam Cameron. Aug 29, 2010 7:01 AM (in response to YogeshM)From my reading of the HTML spec, it's not a bug, it's how the onchange event works. The spec says:
The onchange event occurs when a control loses the input focus and its value has been modified since gaining focus
(My emphasis).
(http://www.w3.org/TR/html401/interact/scripts.html#adef-onchange)
When changing the control's value via script, the control never gets the focus, so implicitly never loses the focus, which is a prereq for the onchange event to fire.
The same thing happens if one changes a normal form input control via script. No event fires.
Adam
6. Re: Using CFINPUT dateField with onChange
YogeshM Aug 30, 2010 4:36 AM (in response to Adam Cameron.)Thanks Adam!
I've come across a possible workaround to this issue.
You can find it here: http://www.coldfusionjedi.com/index.cfm/2008/10/1/Ask-a-Jedi-ColdFusion-datefieldchange-qu estion
Hope this helps others as well.
Regards
7. Re: Using CFINPUT dateField with onChange
YogeshM Aug 30, 2010 4:52 AM (in response to YogeshM)I do however have an issue with the cfinput type datefield.
How do you disable Saturdays and Sundays?
In Flash form and Flex, we only use disabledDays=[0,6]
For example,
<cfinput
type="datefield"id="valuationDate_txt"
name="valuationDate_txt"
mask="dd/mm/yyyy" width="50"
value="#lsdateformat(now(),'dd/mm/yyyy')#"
onFocus="valuationDate_txt.disabledDays = [0,6];">
How do we make the disabledDays=[0,6] work with the cfinput type datefield?Thanks and regards.
8. Re: Using CFINPUT dateField with onChange
Adam Cameron. Aug 30, 2010 5:22 AM (in response to YogeshM)I have no idea, but I would start a new topic rather than tack it on to this one, because that question has nothing to do with the subject line. People who might not know about onchange events but do know about enabling/displaying specific days will perhaps not see your question, as they might not bother reading it.
Adam
9. Re: Using CFINPUT dateField with onChange
gmcfalls Jun 6, 2012 11:03 PM (in response to DLAH)This may not be the most elegant solution out there, but it works okay.
====== Javascript Code ======
i = 0;
function doSubmit(caldate) {
i++;
if (i>1) {
window.location = "index.cfm?caldate=" + document.getElementById('caldate').value;
=====CFML Code ======
<cfform ... typical code here ....>
<cfinput type="datetime" id="caldate" ...typical code here .... />
<cfajaxproxy bind="javaScript:doSubmit({caldate})">
</cfform>
What this does is fires doSubmit each time the form controls are touched or the value is modified. When this happens, it will increment i. You will fire doSubmit twice (once to open the calendar and then once when a date is actually selected). So you want to fire when i = 2 or when i > 1.
10. Re: Using CFINPUT dateField with onChange
rumbizumbi May 17, 2014 12:12 AM (in response to DLAH)Not a very elegant solution also, but it works
Use an JavaScript onclick event in the cfform tag.
Check if the old value is not the same as the new value and execute your code:
<cfform name="form1" format="html" skin="haloBlue" style="display:inline;"
onclick="if(document.getElementById('startdate').value != '' && oldval != document.getElementById('startdate').value)
{alert('changed')}"><cfinput type="dateField" name="startdate" id="startdate" style="width: 65px" mask="DD.MM.YYYY" value="#mydate#">
</cfform>
<script type="text/javascript">
var oldval = document.getElementById('startdate').value;</script>
regards
rene
