1.insert ByteArray into or select from mysql blob with PHP ERROR
The default code is error, I couldn't insert ByteArray data into mysql till I add the mysqli_send_long_data() method.
- $stmt = mysqli_prepare($this->connection, "INSERT INTO $this->tablename (info, info2) VALUES (?, ?)");
- $this->throwExceptionOnError();
- mysqli_stmt_bind_param($stmt, 'bs', $item->info, $item->info2);
- mysqli_send_long_data($stmt, 0, $item->info);
- mysqli_stmt_execute($stmt);
And add $stmt->store_result(); when you get blob data:
- $stmt->store_result();
- foreach($rows as $value){
if($value->info){
$value->info = new Zend_Amf_Value_ByteArray($value->info);
reference:
http://blogs.sun.com/oswald/entry/php_s_mysqli_extension_storing 2.Test Operation is ok, but use in application couldn't work. I have to change the PHP function name to make it shown in flash builder color "gray" , and then it works.
3.The auto created method like update... and delete... should be like below, return the affected num.
- $affected = mysqli_stmt_affected_rows($stmt);
- mysqli_stmt_free_result($stmt);
- mysqli_close($this->connection);
- return $affected;
