Hello,
This may seem to be a very elementary questions but I am missing something that I have not been able to identify and am asking for anyone's assitance with this.
In my form I am comparing two dates (<Date1> and <Date2>). If <Date2> is less that <Date1> I would like to display a message box and then set the focus to <Date1>.
I have tried numerous variations using Date2Num and .Rawvalue but the code seems to be skipping the IF THEN statement and goes directly to displaying the message. On Exit from the <Date2> field the message box appears regardless if the date is less than, equal to, or greater than <Date1.
Here is the code...
topmostSubform.Page1.<Date2>::exit - (FormCalc, client)
if
(Date2Num(<Date2>,"DD-MMM-YY") < Date2Num(<Date1>,"DD-MMM-YY")) then
xfa.host.messageBox("<<< CAUTION >>> Your <Date2> cannot be earlier than your <Date1>. Please correct your <Date1> date. Thank You")
xfa.host.setFocus("<Date1>")
Endif
Thanks.
TST
Total Likes
When referencing an object you do not use <Date1> ....you woudl use the name of the field and a method or property. In your case ....assuming the field is called Date1 then you woudl use Date1.rawValue
Paul
Total Likes
