I am using RH8.0.2.
When i click on the hyperlink text it navigate to the correct page,but in the TOC content the topic which is displayed is not highlighted.Insteed it remain the page from where it is clicked remain highlighted.
For example: As in Fig1,if i click on the "TMD PDU" it navigate to the right page as in Fig 2,but in TOC "E-UTRA RLC Messages Overview"remains selected.Ideally in TOC "TMD PDU" page should be highlighted.
How to solve this issue?
Fig1
Thanks and Regards,
Rahul
Hi Rahul
There are a couple of things you need to check here. I'm going to assume from the images, that you are creating CHM files.
First, open the Project Set Up pod and expand the Windows folder. Then edit the properties of your CHM window and ensure the option to synchronize the TOC has been enabled.
Once you have done this, edit the Single Source Layout properties and click the Edit... button. This should open another dialog where you would click the TOC Styles tab. Ensure you enable the Always
...Copy link to clipboard
The obvious question here, is this: has that topic actually been assigned to the TOC?
That is, in the Topic List pod, is the "TMD PDU" topic's value under the TOC column "Yes"?
Good luck,
Leon
YES
Br,
Rahul
Did you duplicate the topic in Fig. 1 and neglect to change the title of the topic copy (see the <title> tag in the <head> section)?
Good luck,
Leon
Hi Rahul
Once you have done this, edit the Single Source Layout properties and click the Edit... button. This should open another dialog where you would click the TOC Styles tab. Ensure you enable the Always Show Selection option.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
Yeah...what Rick said.
Good luck,
Leon
