Error getting license
License server communication problem:
E_LIC_ALREADY_FULFILLED_BY_ANOTHER_USER
Okay we are receiving this error and have several customers who are also receiving.
We have tried the following solutions and end up back at the same "Error" again
1) Customer downloads and installs Adobe Digital Editions (mind you that they do not change machines - they are only using this on the one machine)
2) Customer completes the installation with an Adobe ID
3) Customer downloads a book from the Adobe Library online - (just to test to make sure they can get books)
4) The error message appears - they click okay - but they cannot download any further
We have tried the following:
1) Uninstallation
2) Removal of Cache / Internet Files / Temporary Files
3) Removal of the License Key from the Registry in Windows XP
4) Manual Installation of the Adobe Digital Editions software from the Adobe website - setup involved anonymous activation
5) Creation of a "new adobe id"
6) Activation of ADE with an Adobe ID
7) We have removed and installed several times - and the error continues to return
We're moving in the same circle over and over again - I even tried searching the Web - but apparently can't find anything at this point, I would just like to be able to resolve this issue and fix our customers.
LindaB
After a long and indepth process - we figured out a resolution on our own. So much for putting in a case and receiving no response.
Would love it if you could share it with me. your solution.
am facing the same problem. can u mail me at lothika.sharma@gmail.com???
Please share, as it look like at lot of people has got the same problem...
Thank you..
"I am getting the error 'Error getting License: License server
communication problem: E_LIC_ALREADY_FULFILLED_BY_ANOTHER_USER' when
opening Adobe Digital Editions."
This error message is a result of a several different issues:
User has installed an Adobe ID on more than one machine
User has modified the clocks on their computer
User has modified their account from a "Do Not Authorize" to an "Adobe
Activated ID"
User has uninstalled and re-installed Adobe Digital Editions, but the
installation is not being completely removed from the computer.
Resolution: Follow these steps:
Uninstall Adobe Digital Editions using one of these two methods:
Start > Programs > Adobe > Adobe Digital Editions > Uninstall
Start > Settings > Control Panel > Add Remove Programs
Initiate Uninstall
In order to remove all remnants of Adobe Digital Editions / Adobe Adept
from the machine a "Registry Edit" will need to be performed:
Start > Run > Regedit
Search for HKEY_CURRENT_USER > Software > Adobe > Adept and Delete the
full "Adept" folder
Remove only the structures that are under the "SOFTWARE" extensions.
This will remove the Adobe ID / License and Activation Keys
Clear any outstanding tasks that may be associated to Adobe Digital
Editions downloads
C:\data\my digital editions
C:\my documents\my digital editions
Delete any documents within these folders:
Restore > Tasks
Restore > Failed
Re-install Adobe Digital Editions
I was having the same problem Had just uninstalled ADE 4.5 and installed ADE 3.0 at my library's suggestion. They suggested borrowing another book that I had not put on another device and then downloading. It worked and I can now borrow books again
Well, thanks for saying you found a fix and then not posting the fix. That's helpful.
what would that solution be?
could you be so kid enough to post it?
Having the same problem
got the same problem, nobody gives any solution in here?
