Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Problem with "if" expression
Avatar
Level 1
I'm creating a form in which I'm comparing a numeric field with a numeric value typed in it using the expression "if" (I'm using FormCalc language) in order to generate another numeric value automatically in another NumericField , the script goes like this:
if (NumericField1 ==1) then
     NumericField6 = 100
endif
I type this script in NumericField6 and I used the script check option and marks no errors in the script but when I use Acrobat to test the form (typing "1" in NumericField1) it doesn't generate automatically the 100 value in NumericField6. Can someone help me telling me why the script is not working? or how can I do to generate a numeric value in another NumericField depending of the numeric value typed in a previous Field?
Thanks in advance.
1 Accepted Solution
Avatar
Correct answer by
Level 8
You need to compare the value of your numeric field and not the field itself:
if (NumericField1.rawValue ==1){
     NumericField6.rawValue = 100
Avatar
Correct answer by
Level 8
Avatar
Level 1
Dude. thanks a lot !!!!!, you have no idea how many days I have been trying to do this form to work, again thanks!
