Thanks everyone for all the suggestions. The udf worked
great!
Bryan Ashcraft (remove brain to reply)
Web Application Developer
Wright Medical Technologies, Inc.
Macromedia Certified Dreamweaver Developer
Adobe Community Expert (DW) ::
http://www.adobe.com/communities/experts/
"Stefan K." <webforumsuser@macromedia.com> wrote in
message
news:e4eldj$9mv$1@forums.macromedia.com...
> ScareCrow is correct.
> Passing a list as IN-parameter to a stored procedure is
bound to fail.
> SQL simply treats a list as a string, by no means a a
list of
> numeric-values
> or list of several strings.
> The simple workaround would be to write a normal query,
don't use stored
> proc
> in this case.
> The other way is using one of the following SQL-udf,
they take such a
> string-list and returns a temp-table(position, value).
> There's a version for working with string-lists and one
for numeric-lists.
> Example:
> SELECT TOP 1 *
> FROM dbo.udf_iter_stringlist_to_table(
'firstItem,secondItem', ',')
> Would return:
> listpos | string
> 1 | 'firstItem'
> Numeric-list UDF:
> CREATE FUNCTION dbo.udf_iter_intlist_to_table (@list
ntext, @delim nchar)
> RETURNS @tbl TABLE (listpos int IDENTITY(1, 1) NOT NULL,
> number int NOT NULL) AS
> BEGIN
> DECLARE @pos int,
> @textpos int,
> @chunklen smallint,
> @str nvarchar(4000),
> @tmpstr nvarchar(4000),
> @leftover nvarchar(4000)
> SET @textpos = 1
> SET @leftover = ''
> WHILE @textpos <= datalength(@list) / 2
> BEGIN
> SET @chunklen = 4000 - datalength(@leftover) / 2
> SET @tmpstr = ltrim(@leftover + substring(@list,
@textpos,
> @chunklen))
> SET @textpos = @textpos + @chunklen
> SET @pos = charindex(@delim, @tmpstr)
> WHILE @pos > 0
> BEGIN
> SET @str = substring(@tmpstr, 1, @pos - 1)
> INSERT @tbl (number) VALUES(convert(int, @str))
> SET @tmpstr = ltrim(substring(@tmpstr, @pos + 1,
len(@tmpstr)))
> END
> SET @leftover = @tmpstr
> END
> IF ltrim(rtrim(@leftover)) <> ''
> INSERT @tbl (number) VALUES(convert(int, @leftover))
> RETURN
> END
> String-list-UDF
> CREATE FUNCTION dbo.udf_iter_stringlist_to_table (@list
ntext, @delim
> nchar)
> string varchar(8000) COLLATE database_default NOT
> NULL) AS
> BEGIN
> DECLARE @pos int,
> @textpos int,
> @chunklen smallint,
> SET @textpos = 1
> SET @leftover = ''
> BEGIN
@textpos,
> @chunklen))
> WHILE @pos > 0
> BEGIN
> INSERT @tbl (string) VALUES(@str)
len(@tmpstr)))
> END
> END
> INSERT @tbl (string) VALUES(@leftover)
> RETURN
> END
