Up to now I have been doing my voice overs onto Captivate v4 using a USB headset with microphone.
Despite spending a serious amount of money on a Sennheiser headset, the quality is just not good enough, especially after I have edited some of the slides a few times.
Someone has suggested the problem is more likely the USB connection between headset and laptop and I would be bettter of with a standalone microphone connected to my Laptop via the usual jackplug.
Does anyone use such a microphone and if so, could they recommend their make/model?
Noel
Staffordshire
England
Hello Noel,
I do use a USB-microphon and am rather satisfied with the quality, but only recorded with CP5. You can plug a headset right into the mic for monitoring. It is the Shure PG42, and aimed at recording voices. If you want to listen to a recording, I used it for the video tutorial on Conditional Actions. Please do not pay attention to my accent, I'm not used to speak in English:
Lilybiri
Thanks Lilybiri,
I think your accent is fantastic....could listen to you all day!
I will check out the Shure PG42.
Thanks again,
Noel
Hi Noel,
I use this: http://www.samsontech.com/products/productpage.cfm?prodID=2010
It's called "Go Mic"
It's small, cheap (around 50,- € in Germany) and really good. No noise, crystal sound, direct monitoring, small.
Best
Ishan
Thanks Ishan,
I will check it out.
Noel
