RH8 List Styles - benefit of?
Guest
Sep 03, 2010 Sep 03, 2010
In RH8 list styles are separate from paragraph styles.  Can anyone tell me why I would use a list style for a bullet or numbered list, rather than using a paragraph style - and applying the bullet or number with the toolbar button?
It seems that the paragraph style/button method produces a more stable result in Print Documentation however I would like to know if I'm losing out on something by not using 'list style'.?
thank you for any light you can provide.
772
Advisor ,
You're "losing out" on those ugly bruises from repeated slamming into a stone wall.
In other words, keep doing what you're doing.
Good luck,
Leon
Leon
Are you thinking of ordinary list or multi level lists?
Mpali
For ordinary lists I suggest taking a look at Snippet 129 on my site. RH8 generates XHTML output and you will likely have problems if you apply the bullet definition within a paragraph style.
@petergrainge
Guest
Peter,
I am talking about simple bullet or procedure steps. The paragraph style does not have the bullet within it, I apply the bullet or number using the toolbar buttons.
Seems to be working okay in the help system and like I said, the Print output is easier to modify.
I just want to avoid the "should-a/could-a/would-a" mantra
Marie P Affa
Manager - Technical Publications
Netsmart Technologies
(631) 968-2037
Guest
Thank you for the laugh of the day. So funny but so true..
I wish my organization would give up on the printed copy manual. Life would be easier for sure.
Marie P Affa
(631) 968-2037
Yes using a paragraph style that does not have any bullet definitions in it plus the bullet/number icons is fine.
@petergrainge
Jan 31, 2011 Jan 31, 2011
One reason for using the list styles is to build a custom bullet such as where a specific image precedes the bullet so I can follow corporate standards.
You can also control the spacing between bullets, i.e., maybe all paragraphs are separated by double-space, but you can set your bullets to be single-space. You could even change the font style.
To keep the custom bullets I have made via list styles in my print output, I make sure to use the "project CSS" during the generate process.
RoboHelp Documentation
Download Adobe RoboHelp
