Has any one else seen this problem with CFMX (6,1,0,63958).
I have some queries running on a site with the version of CF
listed above where we had trim() statements around a form field
which was then used as a value for a cfqueryparam tag in an update
query, and the ' were escaped to ''. There were even some cases of
" going to \" and i think a few ' going to \'.
We developed this on a CFMX box (6,1,0,83762) where this
didn't happen at all.
I even output the variable before and after the update, and
the value had the orginal number of quotes, but the param value
from the query always had it doubled.
This is the section of code i'm talking about.
communityShortDesc = <cfqueryparam
cfsqltype="cf_sql_longvarchar"
value="#trim(attributes.communityShortDesc)#">,
That above statement would cause the ' to double, but just by
taking out the trim like below, the ' wouldn't double.
value="#attributes.communityShortDesc#">,
I think the only option I have is to go through and find all
the trims in the insert/update statements and remove then. I'm just
curious if anyone has any other ideas for this.
Sean
