12 Replies Latest reply: Sep 9, 2010 10:15 AM by cjacs987654 RSS
    Hard Drive setup for CS5 master collection
    cjacs987654 Community Member
      Dear All,
      I am looking for advice on what drive configuration to use. I am currently reformatting all drives for a new cs5 install and have the following drives:
      1. WD Raptor 10000rpm 150gig
      2. WD Raptor 10000rpm 300gig
      3. Seagate 7200 rpm - 1.5tb
      4. Seagate 7200 rpm - 1.5tb
      I have read various forum messages, but need some clarification on what to install on what drive
      I have Windows 7 Ultimate 64-bit with 6 gig memory and i7 processor
      I assume windows is best installed on either of the faster WD drives. and my  video projects on the seagate drives.
      Where should cs5 program files be ?
      I have raid options but dont know a lot about the best set up
      Any advice most welcome, would like to try to get it right first time!
      Regards
      Chris Anderson
        • 1. Re: Hard Drive setup for CS5 master collection
          John T Smith CommunityMVP
          Read Harm on drive setup http://forums.adobe.com/thread/662972?tstart=0
          - click the embedded picture in Harm's message to enlarge to reading size
          Windows and all software on boot drive
          #2 drive = Windows page file
          #3 drive = PPro project files
          #4 drive = video files
          HOWEVER... some types of HD files work best via RAID due to the data transfer speed requiement... but I edit AVCHD without raid since it is more CPU intensive than disk intensive
          You need to post the type of file(s) you will use for someone to give advice on RAID or not
          • 2. Re: Hard Drive setup for CS5 master collection
            Hi John
            Many thanks for your reply and the link to harms article.
            When you say video files on drive4 , do you mean the 'scratch disks' in the project setup
            I am fairly new to premiere , previously I had everything on 2 disks, system and data.
            Many thanks
            Chris
            • 3. Re: Hard Drive setup for CS5 master collection
              Harm Millaard CommunityMVP
              Scratch files (media cache, media cache database and previews) on #2 and the media (video material) on #4.
              • 4. Re: Hard Drive setup for CS5 master collection
                Hi Harm
                many thanks for your reply. I am considering purchasing new HD's specific to build a machine just for CS5.
                What would you recommend for performance. No price budget as such.
                Im thinking 15000rpm.
                Im thinking SATA - is this the fastest?
                Do i have to consider the motherboard to support fast sata drives? - i am confused as i see you can get sata drives with a 6gig transfer speed, does this depend
                on the motherboard?
                Would a bigger cache ie 64mb make a good improvement?
                Chris Anderson
                • 5. Re: Hard Drive setup for CS5 master collection
                  Chris,
                  15K disks are exclusively SCSI, not SATA.
                  SCSI is even faster than SATA but very expensive, small storage capacity and requires expensive SCSI controllers. IMO SCSI is overkill and a waste of money.
                  SATA 3 with 64 MB cache is very nice, WD Caviar Blacks, however they do not offer performance gains over simple Samsung F3's. For really fast storage you need a large array and then the Caviar Blacks are not first choice because of the WD TLER 'feature'.
                  • 6. Re: Hard Drive setup for CS5 master collection
                    Hi Harm
                    Thanks again for the valuable info. Since your last email I have been researching hard drives and been looking at solid state drives such as:
                    http://www.crucial.com/uk/store/partspecs.aspx?imodule=CTFDDAC064MAG-1G1
                    This has 6gig transfer speed. I assume my motherboard would have to support 6gb or get a 6gb controller and obvoiusly 6gig data cables
                    which I know i can get from my local store.
                    This one is 64gig, that would be good for the windows drive and perhaps another one for the scratch disk etc
                    What you do think? Do you have any experience of SSD's ?
                    What drive setup do you currently have?
                    Regards
                    Chris
                    • 7. Re: Hard Drive setup for CS5 master collection
                      Chris,
                      SSD's are great for notebooks and possibly for a boot disk but not for storage of video material and editing.
                      If you have unlimited funds available and a couple of 19" racks, you may get better performance with the same storage as conventional disks for around $ 50 K.
                      SSD's /GB is about 50 times more expensive than conventional disks.
                      • 8. Re: Hard Drive setup for CS5 master collection
                        lmcwilli Community Member
                        Given the 4-drive scenario being discussed here, if you have only two SATA 6.0 Gb/s ports on your mobo (e.g., P6X58D Premium), which of the 4 drives should you connect for the most CS5 bang-for-the-buck?
                        • 9. Re: Hard Drive setup for CS5 master collection
                          Hi Harm/All,
                          not exactly unlimted budget certainly not 50k!!
                          Ok, after doing a bit of research (and checking my piggy bank)  I have decided to spend a few pennies.
                          Disk 1 - Crucial c300 64gig SSD drive - sata3 - 6gb interface - 335mbs read 70mbs write - Windows /Program Files drive.    £95
                          (with ASUS 6gb sata controller card)
                          Disk 2 - 60GB Corsair SSD Force Series - sata2 3 gb interface.   around 280mbs read and write. Page file/temporary files. £93
                          • 10. Re: Hard Drive setup for CS5 master collection
                            Oops my last post got truncated for some reason, ignore tha
                            t one and check back in 10 mins
                            • 11. Re: Hard Drive setup for CS5 master collection
                              Hi Harm/All,
                              Disk 1 - Crucial c300 64gig SSD drive - sata3 - 6gb interface - 335mbs read 70mbs write - Windows /Program Files drive(with ASUS 6gb sata controllercard)
                              Disk 3 - 120gb Corsair SSD force series - sata2 - 3gb - around 280mbc read and write -Project/Media cache and other cs5 files
                              Disk 4 - WD raptor 10k rpm - 300 gig - scratch disk
                              Disk 5 - WD raptor 10k rpm - 150 gig - scratch disk
                              Disk 6 - Seagate Barracuda 7200rpm. 1.5tb - source files
                              Disk 7 - Seagate Barracuda 7200rpm. 1.5tb - source files
                              How does that sound? - Any changes?
                              Disks 1 - 3 will cost me £400
                              Regards
                              Chris
                              • 12. Re: Hard Drive setup for CS5 master collection
                                Hi
                                See my new drive list - I have bought a sata3 6 gig controller card for around £25 to connect the Crucial SSD 64gig 6gb drive
                                All others on sata2 connections on motherboard
                                Chris
