13 Replies Latest reply on Oct 5, 2010 2:56 PM by MrsVJW
    Hyperlinks broken after updating to 9.3.4
    moonchildokc
      Since updating Adobe Standard to 9.3.4, all our hyperlinks are broken.  It appears that if we put the linked document (Excel or Word) in the same path as the PDF (ie; both PDF and document are on the desktop) then the links work.  However, the way our files are set up, all the PDF's are in one directory and all the linked documents are in a different location.  They worked fine prior to the update; now none of them work.
      I have tested this on two other computers.  Works fine prior to running the update.  Once the update is installed, none of the links work.
