Show 5 replies
1. Re: Three-way color corrector
dradeke Sep 8, 2010 2:39 AM (in response to AudoWarp)What if you pull the midtone wheel? Are you able to manipulate the image at all? Is the effect turned on?
2. Re: Three-way color corrector
AudoWarp Sep 8, 2010 3:09 AM (in response to dradeke)Yes, the two wheels to the left alter the image.
3. Re: Three-way color corrector
AudoWarp Sep 8, 2010 3:10 AM (in response to dradeke)Eyedroppers do nothing.
Is this an error?
4. Re: Three-way color corrector
Ann Bens Sep 8, 2010 3:25 AM (in response to AudoWarp)The image probably does not need white balancing.
Post an image and we can have a look.
5. Re: Three-way color corrector
jkosmicki Sep 8, 2010 9:03 AM (in response to AudoWarp)The default when you add the 3-way CC is the adjustments for highlights (this includes the white balance adjustments), so you will want to change the drop-down from "highlights" to "master" otherwise you are just white balancing the highlight range and not the overall image.
