Dear all,
I use RoboHelp 8 to import Word documents and generate a WebHelp output.
When importing the Word document all blanks are replaced automatically
by underscore _ , is it also possible to reclace automatically umlaute ä, ö?
If it is not possible to replace them automatically, is it possible to
do it with find - replace (the file name, not the topic title!)
thank you in advance
andreas
Hi Andreas.
Your options are to either replace the umlaute in the Word file before you import it (something that maybe too much trouble) or changing the topic properties inside RoboHelp. If you rename topics inside RoboHelp you'll be fine. It is only if topics are changed outside of RoboHelp that you'll run into trouble.
The RoboColum(n) | @robocolumn | Colum McAndrew |
Hello, Andreas.
I can't find any Import options in RoboHelp to replace characters in file names. I think even the _ is not optional; RoboHelp does not allow spaces in file names at all.
The Find and Replace inside RoboHelp only affects words inside the files, not the filenames themselves.
I looked in the online help for Windows (my version is XP, but I think it applies to others). It has a Rename (ren) command that you can use to rename multiple files at a time, using wildcards (* for any character or group of characters). For example, you could type ren *ä* *a* to change ä to a in filenames and folders.
Take a look at your version of Windows help and see if this will work for you.
Elisa
Dear Elisa,
thank you for your time to supply an answer out of RoboHelp.
Isn' t it dangerous to change the html-file names? I think this will
lead to errors like 'missing links' ....
What's your or the forums opinion?
thank you in advance and best regards
Andreas
Hi Andreas.
I've done some drastic renaming of files, but then you need to make sure you do it everywhere where there's references to those files.
This assumes that you are comfortable editing the help project files manually.
I've been using FAR from http://www.helpware.net/ to do the more complicated Find/Replace jobs but my version has sometimes broken characters in some of the more exotic languages, using UTF-8 encoding.
What I'd try, using RH7: Find and replace all file names, find and replace the references inside all .htm, .hhc, .hhk and .hhp files (not using RoboHelp for this). Create the help project from scratch by opening the .hhp file in RoboHelp. Check project settings.
Better make a spare backup copy of the help project if you try this.
Wow, why go to all that trouble when if you just stick to Colum's way you are safe? That's the beauty of a tool such as RoboHelp.
Seems like you are creating a lot of unnecessary work for yourself.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
It may depend on how many file names you need to change.
If you have 200 files with ä, ö, å. ü, etc. in the name... it may be faster to do it outside RH.
LOL, okay I see your point.
However, in reading what you wrote it occurs to me that if these letters have been used in the file name, they might also be used elsewhere in general text, no? If you are performing a massive find and replace operation to substitute one letter with an underscore, what do you do to prevent regular text from the operation?
Cheers... Rick
So maybe a combination? (And I apologize for not talking about the Find and Replace of the references to the changed filenames after changing the filenames outside of RoboHelp. I would have remembered to do so in real life...probably...)
And maybe an Adobe enhancement request for an option to convert import filenames to ASCII?
(I have a suspicion that this issue is going to come up on my project in the next year or so.)
Elisa
