Show 2 replies
1. Re: Why isn't the Flash file showing in the browser at true size?
Ned Murphy Sep 10, 2010 6:52 AM (in response to dbthumb)Your monitor settings are defining how large things appear. Things displayed on your monitor are based on pixels. Flash content normally renders at 72 pixels per inch. So if you could adjust you monitor settings such that they too would display 72 pixels per inch, then you would see the Flash piece at the size you intend... that's foregoing any effect resulting from zooming with the browser. But since the settings for your monitor are not normally fine-tune-able (meaning you have to select particular value pairs, such as 800x600, 1024x768, etc) it isn't likely you will get an exact value, and even if you do, someone else's machine will have its own settings.
2. Re: Why isn't the Flash file showing in the browser at true size?
dbthumb Sep 10, 2010 8:16 AM (in response to Ned Murphy)I figured it had to be a resolution setting. I appreciate your help, thanks.
