1. Re: Bridge CS5 doesn't see changes made by LR3
Curt Y Sep 13, 2010 7:32 AM (in response to deedeecz)Don't use Lightroom, so just a guess. Make sure LR writes to metadata file. Believe LR uses a database and Bridge uses XMP sidecar file.
2. Re: Bridge CS5 doesn't see changes made by LR3
A. Wayne Webb Sep 13, 2010 7:57 AM (in response to Curt Y)I have made this recommendation several times in the past but it would seem
to be needed once again.
You really should embed metadata into the file from within Bridge. To do so
go to Tools > Create Metadata Template to create a template for a set of
images. Since most of the people on this list appear to be photographers
this would be an ideal scenario. Create your template and then navigate to
your directory of image files and apply the metadata to the entire range. To
apply a template to an entire set of files hit Ctrl+A to select and then go
to Tools: Append Metadata or Replace Metadata. Each offers slightly
different options.
By following this workflow you ensure that the metadata is an integral part
of the image itself, and not a separate file (XMP sidecar) that can over
time get lost.
Wayne Webb
Digital Archivist
3. Re: Bridge CS5 doesn't see changes made by LR3
Curt Y Sep 13, 2010 10:03 AM (in response to A. Wayne Webb)A. Wayne Webb wrote:
time get lost.
It is my understanding that some metadata is stored on the image, and some stored as either an xmp sidecar fie, or in a data base, depending on option selected. The last option is not recommended by the "experts". This mainly pertains to images edited in ACR.
All the metadata is written to the file if the images are converted to DNG files.
I could be wrong, so can you clarify how the template would write directly to the image rather than the xmp file?
4. Re: Bridge CS5 doesn't see changes made by LR3
deedeecz Sep 13, 2010 1:47 PM (in response to Curt Y)I got this reply in LR forum:
"By default the adjustments are only saved to the Lr catalog. To be seen by Bridge you must save the settings back to the original file (keystrokes Cmd/Ctrl+S)."
I tried ctrl + s in LR but the image hasn't chnged in Bridge Instead, 2 small, round grey icons appeared in the upper right corner of the image in bridge(one for cropping and one dor levels). The image itself hasn't chnaged.
UPDATE: After clicking Ctrl+s it was just a matter of setting previews in Br to high quality
