HELP!
May 19, 2006 May 19, 2006
common no one can help out with xml issue? how to insert an element at a specific position?
iam using this ArrayInsertAt(mydoc.employee.name, 2, XmlElemNew(mydoc, "PhoneNumber")
but if the xml doc has only on2 element it alerts me that i cannot insert at position 2! but i need to insert it at the end!
anyone help please!
Advanced techniques
592
Contributor ,
If you need to add something to the end of an array, use ArrayAppend.
Are you looking for a way to add a 3rd element to an XML document that already has 2 elements? Something like this should do it:
May 21, 2006 May 21, 2006
Hello BKBK and thx for your reply!
well my problem is how to insert an element between element1 and element2 ..
can you help out with this?
thank you alot for your time.
regards
Engaged ,
credev this is what you are trying to do:-
May 22, 2006 May 22, 2006
worked with this
ArrayInsertAt(xmlDoc.MyDoc.XmlChildren,#position# , XmlElemNew(xmlDoc,"TagTR"));
thnx guys
yes exactly Stressed_Simon it works like that but now iam facing another problem.
when i put values to node like below and later when i do transformation for xmlDoc to HTML
xmlDoc.MyDoc.TagTR[#position#].XmlChildren[2].XmlText = "Palette Hétérogène";
i receive the following Palette Hétérogène its an encoding problem ... how can i solve it?
An idea
May 23, 2006 May 23, 2006
BKBK i tried it but the output was the same
Palette Hétérogène
what do you think?
what do you think?
I think you did not put the output between cfoutput tags or within WriteOutput(). If you do, you will get Palette Hétérogène.
BKBK this is not it! i already put cfoutput else it would have given me an error.
listen this is my function
<cffunction name="addNewElement" returntype="void">
<cfargument name="position" type="numeric" required="yes">
<cfscript>
StructInsert(xmlDoc.MyDoc.TagTR[#position#].XmlAttributes, "index", "index");
xmlDoc.MyDoc.TagTR[#position#].XmlChildren[1] = XmlElemNew(xmlDoc, "TagTD");
StructInsert(xmlDoc.MyDoc.TagTR[#position#].TagTD[1].XmlAttributes, "libelle", "Emballage");
xmlDoc.MyDoc.TagTR[#position#].XmlChildren[1].XmlText = "Palette Hétérogène";
</cfscript>
</cffunction>
and this is my xsl to transform it to html
<?xml version="1.0" encoding="ISO-8859-1" ?>
<xsl:stylesheet
version="2.0"
xmlns:xsl=" http://www.w3.org/1999/XSL/Transform"
xmlns=" http://www.w3.org/TR/REC-html40">
<xsl utput method="html" encoding="utf-8"/>
<xsl:template match="MyDoc">
<xsl:for-each select="TagTR">
<tr class="Arial_2_noir" height="10" align="left" valign="top" bgcolor="#CCCCCC">
<td><xsl:value-of select="TagTD[@libelle='Emballage']" /></td>
</tr>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
so in brief i have an xml Object (cfxml) which i added an element to it then i transform it to HTML and dump it to browser.
anyone can see why i have that problem? my output is "Palette Hétérogène" instead of "Palette Hétérogène"
Documentation
